I have david bradley,took the clutch assembly apart for repair,and now I am having time trying to put it back together.I have the spring type clutch, and in order for me to put it back together I have to compress the spring , so is there a trick on how to do that?
david bradley clutch
#1
OFFLINE
Posted May 14, 2016 - 09:35 PM
#2
OFFLINE
Posted May 14, 2016 - 11:59 PM
no real trick as that's an easy clutch, just get the bearing and washer behind it right, slide the inner plate on, then a clutch disc, the pully, another clutch disc, then the outer cup. all that's left is putting the pin though the outer cup thru the shaft. You need to make sure that you have all the correct parts in there and not ones somebody thought would be a good replacement. Goes to this site and look at the manual pictures of the assembly. we might even have a manual in the walk-behind manual area here. http://amigatec.net/.../David_Bradley/
#3
OFFLINE
Posted May 16, 2016 - 06:03 PM
This clutch is a spring loaded clutch, it has a spring that goes in the spring case and its the first part to go in the output shaft ,and in order for me to put the pin through the outer cup I have to compress it somehow
#4
OFFLINE
Posted May 19, 2016 - 01:23 PM
The clutch lever should compress the spring when disengaged, think it has a cup over the spring.
#5
OFFLINE
Posted October 16, 2017 - 09:51 AM
I am having a problem with clutch sticking on my David Bradley 2 wheel walk behind. When the clutch lever is down it continues driving. any help would be appreciated. thanks
- Zekkjacen said thank you
#6
OFFLINE
Posted November 03, 2017 - 01:35 PM
I'd suggest taking it apart and cleaning it. Dirt is known to get in there
