* * * * - 1 votes
Allis 720 Diesel Repower
172 replies to this topic
#16 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 15, 2016 - 05:59 PM
Ebay sellers have a full aluminum radiator for an early model mini cooper. I have used 2 of them on diesel conversions and they work and cool fine. They are about 11 inches wide and 15 inches tall and about 1 1/2 inches thick. I think I paid $55.00 with free shipping.
THANKS for that info!  I have room for 13" wide and over 17" tall, so that will work just great!
  • KennyP and Auburn David have said thanks
#17 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 15, 2016 - 07:01 PM
Been mocking things up today.  I will need to raise the hood & dash about 1 to 1 & 1/2", and do some minor angled cutting above the axle pivot housing to give oil pan clearance.  I have to machine a flywheel adaptor for the pulley that drives the hydro belts before I can weld in engine mounts.  The same pulley is where the rear PTO shaft bolts to.  The radiator takes up all the room where the battery originally was located, but I "think" I can make room for a GT size battery beside the engine inside the frame rails.
  It will be fairly involved, but to me, it'll be worth the effort.  It took me 5 years to finally finish Hogzilla, and may be quite some time for this project.  I'll hack at it when I find time.
  The hood actually closes in factory position, but not enough room left for air filter hose which comes out the top side of the valve cover.
P_20160515_1634341.jpg P_20160515_1634411.jpg P_20160515_1701211.jpg P_20160515_1701441.jpg
  • TheFarm2004, Texas Deere and Horse, KennyP and 4 others have said thanks
#18 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted May 15, 2016 - 07:19 PM
RAM air hood!!!!!!
  • olcowhand, Wm McNett, KennyP and 1 other said thanks
#19 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 21, 2016 - 04:21 PM
Just ordered a Mini-Cooper radiator, 10" electric fan, and a fan thermal switch for this project.  Figured best to get all needed parts stockpiled so I can fab what's needed as time allows.
#20 KennyP ONLINE
  • 41,506 Thanks
  • 47,418 posts
Posted May 21, 2016 - 04:57 PM
Cool! That's what you're after anyway!
  • olcowhand said thank you
#21 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 2,066 Thanks
  • 1,114 posts
Posted May 21, 2016 - 11:42 PM
Can't wait to see the look on your face when this one runs under her own power. Bet it beats the one from the HD12!
#22 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 27, 2016 - 07:22 PM
Radiator and fan arrived today!  Gonna be quite a while before I can really get into this project, so these go on a shelf till then.  I have a thermal switch I'll either mount at the engine, or drill/tap the drain cap & install in this radiator.
#23 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted May 29, 2016 - 01:59 PM
Flea market find for the 720 today....new seat for her.  I'll store all these parts away and be ready this fall or winter when I really get to dive into this project.
  • KennyP and jpswift1 have said thanks
#24 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 2,066 Thanks
  • 1,114 posts
Posted May 29, 2016 - 02:03 PM
I had a feeling there would be something in this thread today!
  • olcowhand and KennyP have said thanks
#25 KennyP ONLINE
  • 41,506 Thanks
  • 47,418 posts
Posted May 29, 2016 - 05:10 PM
He's getting the itch!
  • olcowhand and SupplySergeant have said thanks
#26 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted June 26, 2016 - 08:24 PM
Just been too busy at work and home with hay & such to do any tinkering, but this project is on my mind a lot still.  Hoping for this hot weather to break so I can get some time in  on it.  My next thing to do is to take the old drive coupling off the flywheel so I can machine it to fit the OE belt pulley to drive the tranny belts and PTO shaft.  Once that is done, then I can get the engine mounts built & really get into things.
  • TheFarm2004, wvbuzzmaster and KennyP have said thanks
#27 A720C OFFLINE
A720C
  • 5 Thanks
  • 11 posts
Posted August 08, 2016 - 07:12 PM
Hope all is going well with the project. I'm doing the same thing with a 20 hp yanmar. She fired last week. Hope to be driving in the next couple weeks
  • olcowhand and MNGB have said thanks
#28 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted August 22, 2016 - 11:16 AM
Boy ,that turned out very nicely. Between you and Daniel, I'm thinking I need to pull the Onan out of my 4140SIM and drop one of my diesels in it.
#29 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted August 22, 2016 - 11:17 AM
What are you doing about using the rear PTO? Did you use the OEM setup and power it the way it was from the factory?
#30 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted August 22, 2016 - 08:01 PM
I am subbed...might steal your dash tower idea for the extra two inches I need for my tractor...
Mike "Squirrelly" Kitko
