Cub 1250 steering column bearing
6 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted May 14, 2016 - 05:17 PM
Would this work ok to beef up the top of a steering column? The bearing fits a hair loose in the column so I cut a piece of tire tube and push the bearing in for a tight fit.
  • Traill95 and Sawdust have said thanks
#2 KennyP ONLINE
  • 38,197 Thanks
  • 45,848 posts
Posted May 14, 2016 - 05:57 PM
Might just work! I've wrapped electrical tape around those and that seemed to help!
  • coinman66 said thank you
#3 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted May 14, 2016 - 06:18 PM
It's a nice fit now and steering works great! Need to get one of those bearings they use on the lower part of steering column. U wouldn't happen to know what size to get would you?
#4 KennyP ONLINE
  • 38,197 Thanks
  • 45,848 posts
Posted May 14, 2016 - 06:27 PM
Is that the Ross steering? I think there is a thread on rebuilding those!
#5 dodge trucker OFFLINE
dodge trucker
  • 2,415 Thanks
  • 3,110 posts
Posted May 14, 2016 - 07:07 PM
What happened to the other steering column that I gave you with that machine? Are you working on that column or the original one that was in the tractor??
#6 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted May 14, 2016 - 07:17 PM
This is the one u gave me Dodge. Just beefing it up a little.
#7 dodge trucker OFFLINE
dodge trucker
  • 2,415 Thanks
  • 3,110 posts
Posted May 14, 2016 - 09:11 PM
oh ok.  I thought that one was pretty good, I was gonna do the thrust bearing upgrade to it before puttin it in. The original one though, the top of the tube was wallowed and rusty. I had talked to others, who said to pull the wheel, pull the tube and cut ~1" from it and put a new top bearing in at that point which would also mean it would have a new spot to ride on the steering shaft .
and the steering shaft would stick out of the tube that much farther though being the same shaft would mean the steering wheel being at the same stock original height.
