Next project: Ripper Bar
43 replies to this topic
#16 KennyP ONLINE
  • 37,551 Thanks
  • 45,535 posts
Posted May 15, 2016 - 04:12 AM
Any discussion on the correct angle they work at? I would like to make them work as efficient as possible so I'm "all ears" on some thoughts or point me to a link for some educational reading?
My sleeve hitch has multiple holes for pivot height as well as adjustment for various lift height.
Currently the rippers are in their lowest adjustment hole and I've decided I will not have to drill any lower holes.
Thanks, having the equipment helps that is for sure!
I was always told to make sure you have nice stuff when they have your estate auction/sale when you are dead and gone so I am just trying to hold my end of that up! LOL
If the sleeve hitch will be horizontal when down, then make the mounting on that plane. Just make sure it will still let you lift out of the ground if the teeth are at max depth.
  • Brucepts and holdenboy1960 have said thanks
#17 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 15, 2016 - 08:34 AM
the 3 tine ......is looking good & some serious dirt work be happening
#18 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,177 Thanks
  • 697 posts
Posted May 15, 2016 - 04:39 PM
I am working on converting a tow behind de-thatcher into a sleeve hitch de-thatcher/ dump rake. Because it will be run at different heights depending on whether I am dethatching or raking hay, I needed to make the angle adjustable so both rows of tines will be level with the ground. The picture below shows where I am with it at the moment. There will be a bracket on the tongue and another on the body of the rake. These will be connected by a turnbuckle to adjust the angle of the rake body. Something similar, but more robust might work for your ripper bar. Another option is in the second picture. Just picked them up this morning.
Jim
  • KennyP, Sawdust and Brucepts have said thanks
#19 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 15, 2016 - 07:16 PM
Jim
Although I live in the country and have farms around me I'll pass on the second pic, I'm familiar with the smell that follows along with them! :thumbs:
  • CanadianHobbyFarmer said thank you
#20 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,177 Thanks
  • 697 posts
Posted May 15, 2016 - 08:49 PM
Are you saying you don't like the smell of bacon? LOL!
Jim
  • jpackard56 said thank you
#21 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 17, 2016 - 06:52 AM
Jim
I like bacon just not the smell before it becomes bacon! LOL
My project is on hold for about a week . . . waiting on a Plasma Cutter to show up that I purchased Monday to assist in future fabrication projects as well as this one :D
I'm tired of the dust from the cut-off wheels and time it takes, been wanting a Plasma for sometime now but wasn't sure. Spent all day Sunday afternoon/evening reading and videos on all I could find on various ones and decided to gamble on a less expensive import (since they are almost all made over there anyways) I ordered a Simadra 50DP from a well respected eBay vendor. I had my eye on the 60amp model from Eastwood but couldn't see spending almost twice as much for something I would only use a couple times a month for hobby work???? I'll do a review in the Tool Shed when I get a chance.
Edited by Brucepts, May 18, 2016 - 07:35 PM.
  • KennyP, Sawdust and CanadianHobbyFarmer have said thanks
#22 tater195 OFFLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted May 17, 2016 - 08:33 AM
https://www.google.c...463577983150310
I bought one of these several years ago (6 or 7 ?) and use it quite a bit. The only problem I have had with it is from burning holes in the airline to the head. I patch those up with electrical tape. It is to the point now where I need to replace it.
Order the extra consumables from ebay. You can get a big batch cheap. The starter pack wont last long
  • Brucepts said thank you
#23 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 17, 2016 - 06:20 PM
Snuck in some time on this project today, figured I could start some layout work on the sleeve to ripper attachment. My plan is to box the area between the sleeve and the shank tube.
All pictures show the attachment from the bottom side
  • wvbuzzmaster, KennyP and michael.kitko have said thanks
#24 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted May 17, 2016 - 06:53 PM
Can I ask a quick question...I see you have the same magnet I do. Does it also have the grinding dust fur? It looks like it does, but if it doesn't, is there any tricks to keeping those clean?
Mike "Squirrelly" Kitko
#25 KennyP ONLINE
  • 37,551 Thanks
  • 45,535 posts
Posted May 18, 2016 - 05:51 AM
Mine get that a lot! I rap them against a wooden table to lose most of it. Rest gets wiped off or blown off.
  • michael.kitko and Brucepts have said thanks
#26 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 18, 2016 - 06:33 AM
I do the same with mine, wipe or blow off. I usually wipe the mating surface off with a rag before I use them so they sit square to my parts.
I picked up the welding table last year at Harbor Freight using the 20% discount when it was on sale, not the best quality but great for the home shop for occasional use, off the top of my head I think it was less than or around $50?
Edited by Brucepts, May 18, 2016 - 06:35 AM.
#27 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 18, 2016 - 02:01 PM
Dollar shave club can fix the "fuzzies" :hitting_self_roller:
  • KennyP, michael.kitko and Brucepts have said thanks
#28 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted May 20, 2016 - 09:02 AM
That's good...LOL...
#29 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 20, 2016 - 07:36 PM
This new toy . . .  er I mean tool showed up today!
Have to get it setup and do some practicing cuts and then get back on fabrication.
I'm going to start a new post in the Tool Shed about this unit, doesn't seem to be alot on the net about it.
#30 Brucepts OFFLINE
Brucepts
  • 178 Thanks
  • 54 posts
Posted May 25, 2016 - 08:05 PM
Got some cutting and welding done today.
  • MH81, Alc, EricR and 3 others have said thanks
