Bolens Tubeframe Sleeve Hitch Question
23 replies to this topic
#16 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted May 14, 2016 - 06:52 PM
Thanks for all the great information and help.  Had a real close look at it today and found a couple of hints that indicate it may have been white at one time so will try and clean it up and paint it white when it warms back up again - 39 degrees F and falling right now.
  • Rock farmer said thank you
#17 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted May 16, 2016 - 06:36 PM
Was going to cut the grass today but it started to drizzle so I switched to plan B - clean up and paint the sleeve hitch.  Got the cotter keys out with a pair of pliers which surprised me as I thought they would be seized in the holes the way it was rust coloured.  Put a wrench on the bolts and they turned a bit with a good pull so I worked them in and out a bit with some penetrating oil applied to the threads and the hitch mounted in the vise and finally got them out and the jam nuts off.  Then I noticed the right arm had a bit of a bend at the end so I dragged the anvil out and found the sledge and gave the arm a few love taps - it flattened out to the point I could live with it and pushed the anvil back in its hiding spot and put the sledge away.  I remember when I was younger the anvil seemed lighter and easier to pick up and move around - it must have gotten heavier with age like me!  Put the wire brush and a maroon scotch brite pad to work and got a lot of the brown rusty look removed and the white paint underneath started to show through.  Gave everything a quick clean and wash and a coat of self etching primer.
  • LPBolens, jpackard56, Sawdust and 1 other said thanks
#18 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted May 16, 2016 - 06:45 PM
Then it got a splash of white paint to make it look respectable again.  It was cool in the shop and the spray bomb was spitting a bit so I got a few runs in the paint but it should slow down the rust to a crawl.
  • Bruce Dorsi, jpackard56, Sawdust and 3 others have said thanks
#19 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted May 18, 2016 - 07:35 PM
Mine is sodi built and A one on piece...  Doe's that make it RARE..???? :dancingbanana: IMG_1435.JPG
  • ClassicBolens and 29 Chev have said thanks
#20 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted May 18, 2016 - 07:48 PM
Looks nice - yours doesn't have the two sets of holes where it attaches to the tractor?
#21 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted May 19, 2016 - 03:48 AM
Looks like yours came with the proper lift rod, neither of mine came with any but I did find out that the tiller lift rod works well enough with them.
#22 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted May 19, 2016 - 04:43 PM
Mine is a homebuilt unit as well. I went with red to match the wheels. Mine does have the two pairs of  holes where it attaches to the axle housing.
Jim
  • Sawdust and 29 Chev have said thanks
#23 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted May 20, 2016 - 10:45 AM
Ya I know I don't have 2 holes in mine.. I was afraid that 2 holes, upper and lower would be weaker in that area..
  • 29 Chev said thank you
#24 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22749 Thanks
  • 7519 posts
Posted June 04, 2016 - 03:01 PM
Was asked if I could make two lift rods and one tube lift the same as mine for another sleeve hitch so I have been gathering supplies and working away at them when I had a bit of free time and ambition.  While there are instructions on how to build one in the manuals section I decided to use the one I had as a pattern - interesting that the one in the manuals section has a longer collar on it and four holes for the pins at the rear.  I used some 5/8" diameter cold rolled for the lift arms - since I do not have a way of bending 5/8" cold rolled easily without heat I opted to cut the rod at the bend and mig welded it back together once I had the angle correct.  At the front I used a short piece of 1/4" x 1" flat bar with a 7/16" hole drilled in it where it will attach to the lift link and used a short piece of pipe to make the stop collar at the rear - slit it and slid it over the rod and once I had it in the correct position welded it to the rod.  For the lift tube I used a piece of 1" O.D. round stock and drilled the centre to 5/8" - drilled a pilot hole in the lathe and then I moved the piece over to the drill press to complete the drilling.  Then I mounted the piece back in the lathe and bored the centre hole out to .675" to match the lift collar from mine.  Then I used a short piece of 1-1/2" flat bar, drilled a 7/16" hole in it for it to mount to the sleeve hitch and welded the flat bar to the sleeve.
  • LPBolens, Bruce Dorsi, Sawdust and 1 other said thanks
