Jacobsen Chief 100A
19 replies to this topic
#16 bessy61 OFFLINE
bessy61
  • 7 Thanks
  • 29 posts
Posted July 26, 2016 - 06:22 PM
Thanks, will look into it KennyP. New question: k181 engine with knock coming from the flywheel side of things engine. New rings, piston and valve. Flywheel has some slop in it. Any takers on any other possible issues to look for while tearing down for the second time.
#17 KennyP ONLINE
  • 38,271 Thanks
  • 45,877 posts
Posted July 26, 2016 - 07:01 PM
Flywheel key bad?
#18 bessy61 OFFLINE
bessy61
  • 7 Thanks
  • 29 posts
Posted July 26, 2016 - 09:53 PM
Ill need to view a manual to see where its located. Also read that incorrect point setting may contribute to the noise. I adj. The gap on new points from.020 to. 018. May be just imagining but seems to be less of a knock. Everything is stock in the engine other than piston, rings plug and valve.
#19 KennyP ONLINE
  • 38,271 Thanks
  • 45,877 posts
Posted July 27, 2016 - 07:25 AM
This engine service manual should show the key. It's between the flywheel and crankshaft behind the nut that holds the flywheel on.
#20 bessy61 OFFLINE
bessy61
  • 7 Thanks
  • 29 posts
Posted December 11, 2016 - 04:52 PM
Would anyone know where I can find the belt guards/guide that mount off the k161/181 engine on a Jake 100A. Can't seem to find the dimensions anywhere off the net. Early '60s Ford/Minneapolis Moline would be similar
