Thanking a Fellow Member
13 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 177 Thanks
  • 292 posts
Posted May 12, 2016 - 11:11 PM
Big shout out to fellow member CRFarnsworth. I was I need of a flex disc for my 1250 Cub and he came through for me. Good thing he only lives a mile away lol. Now I can move on with the 1250 restoration.
Thanks Rick!
  • Bolens 1000, rustyoldjunk, Alc and 6 others have said thanks
#2 coinman66 OFFLINE
coinman66
  • 177 Thanks
  • 292 posts
Posted May 12, 2016 - 11:19 PM
Hope I have fan blade on right?
Edited by coinman66, May 12, 2016 - 11:21 PM.
  • 1964Deere, hamman and wvbuzzmaster have said thanks
#3 KC9KAS ONLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted May 13, 2016 - 04:17 AM
Your "flex" disc looks very distorted....is it installed correctly? Something missing?
  • hamman and KennyP have said thanks
#4 coinman66 OFFLINE
coinman66
  • 177 Thanks
  • 292 posts
Posted May 13, 2016 - 06:33 AM
Kinda what I thought? What could be missing though? When I took flex disc off, there was only one. Pictures I've seen, show 2 flex disc? These could be used flex disc, causing the distortion, but the material they are made from are in much better shape than I took off.
  • hamman said thank you
#5 MH81 ONLINE
  • 29,893 Thanks
  • 29,724 posts
Posted May 13, 2016 - 06:41 AM
Isn't the purpose of the flex disc to allow the joint to move like a universal joint?
If so, the bolts should be staggered, not lined up?
I don't think it's quite right.
  • hamman, wvbuzzmaster, Cvans and 1 other said thanks
#6 DougT ONLINE
DougT
    Dog Approved
  • 6,565 Thanks
  • 4,736 posts
Posted May 13, 2016 - 06:43 AM
Looks like you have an alignment issue with length. The disc should be fairly straight. It looks like it is being drawn away from the fan or the coupler that the fan is on isn't forward far enough. I'm not familiar with cubs but I'd say something isn't right. I'd take the coupler off and set the shaft back to see what would be necessary to get the two flanges to align within the thickness of the disc. Is there supposed to be some kind of a spacer between the discs?
  • Bruce Dorsi, hamman and KennyP have said thanks
#7 KennyP ONLINE
  • 34,182 Thanks
  • 43,306 posts
Posted May 13, 2016 - 07:04 AM
I agree with the alignment issue. Looks like the drive shaft attachment should come back farther.
  • hamman and boyscout862 have said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,191 Thanks
  • 5,786 posts
Posted May 13, 2016 - 07:22 AM
We always called that a "rag" joint. Looks like a mis-alignment problem
#9 Cvans ONLINE
  • 5,774 Thanks
  • 5,734 posts
Posted May 13, 2016 - 07:37 AM
I have to agree with MH81.
#10 coinman66 OFFLINE
coinman66
  • 177 Thanks
  • 292 posts
Posted May 13, 2016 - 07:48 AM
The bolts are staggerd?
#11 coinman66 OFFLINE
coinman66
  • 177 Thanks
  • 292 posts
The bolts are staggerd? Maybe the shaft can be shoved back further?
#12 Cvans ONLINE
  • 5,774 Thanks
  • 5,734 posts
Posted May 13, 2016 - 11:38 AM
I can't remember, what's the connection on the engine end?
#13 dodge trucker ONLINE
dodge trucker
  • 1,881 Thanks
  • 2,489 posts
Posted May 16, 2016 - 06:15 PM
Huh// on the very machine that I got in trade for this 1250, a NH s14 the disc looks just like the one on his puc of the 1250.
  • coinman66 said thank you
#14 olds45512 ONLINE
olds45512
  • 1,112 Thanks
  • 567 posts
Posted May 21, 2016 - 11:26 AM
Some cubs only had 1 disk and others had 2 depending on when they were made. the difference is where the coupler is attached to the driveshaft, to run 2 the pin needs driven out of the coupler so it can slide on the shaft adn you'll need to drill a new hole for the pin or buy a new driveshaft.
Edited by olds45512, May 21, 2016 - 11:26 AM.
