Craftsman DGS6500 model 917.287500
4 replies to this topic
#1 landt OFFLINE
landt
  • 2 posts
Posted May 12, 2016 - 07:23 PM
I;m working on a garden tractor, model 917.287500.  I have replaced the solenoid and switch, but the tractor still will not start without crossing the  solenoid.  Anyone have any ideas what the problem can be?
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted May 12, 2016 - 07:24 PM
Do you have the right switch?
#3 landt OFFLINE
landt
  • 2 posts
Posted May 12, 2016 - 07:28 PM
Yes. Replaced it. Safety switch checks out too.
#4 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted May 12, 2016 - 08:02 PM
Try jumping right from the battery to the small terminal on the solenoid that connects to the key switch. If it turns over, start checking all the safety switches (clutch, pto etc). If it does not turn over, start checking for bad ground connections, starting with the solenoid itself.
Jim
#5 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted May 12, 2016 - 09:09 PM
There are 2 safety switches.1 for the Seat and 1 for the brake. Did you check your Fuse? Should be a 20 amp fuse hidden in there somewhere.
Make sure your new Solenoid is properly secured and grounded.A bad PTO switch on these newer tractors will act like a bad solenoid that doesn't click.
Your tractor wiring is slightly different than the YS4500 I had here.Here's your wiring diagram and parts.
http://www.searspart...1011/00001.html
http://c.searspartsd...1011-00001.png
Edited by EricFromPa, May 12, 2016 - 09:14 PM.
