Case 446 Attachments
7 replies to this topic
#1 gardentractor1231 OFFLINE
gardentractor1231
  • 4 posts
Posted May 12, 2016 - 06:28 PM
I'm looking for attachments for a Case 446 like a plow,tiller,blade,mowing deck,sickle bar, etc. Really anything that will fit
Also looking for a "3 point hitch" or whatever it's called to attach these to my tractor lol.
Looking for the lift/PTO to raise and lower the rear/front attachments.
Any PTO needed to run attachments.
I'm new to the GT world.
Also any advice to these tractors.
#2 KennyP OFFLINE
  • 30,596 Thanks
  • 41,135 posts
Posted May 12, 2016 - 06:30 PM
:wave:  Welcome to the forum!
  • gardentractor1231 said thank you
#3 gardentractor1231 OFFLINE
gardentractor1231
  • 4 posts
Posted May 12, 2016 - 07:01 PM
Thanks glad to be here.
Edited by gardentractor1231, May 12, 2016 - 07:01 PM.
#4 Cat385B ONLINE
    Therapy CAT
  • 12,364 Thanks
  • 9,216 posts
Posted May 12, 2016 - 08:13 PM
You will need to post the year or serial # of your machine or a picture to help everyone know what you have. Different years use different model attachments.
Your machine can use a sleeve hitch or a 3 point hitch.
A rear pto on the Case/Ingersoll GTs is a hydraulic circuit with a valve.
#5 dropped82 ONLINE
dropped82
    Nut Case
  • 1,637 Thanks
  • 1,347 posts
Posted May 12, 2016 - 08:56 PM
All 446's use the same attachments. You get into different ones when your talking 4 digit machines and pre snapfast. The 446 falls in neither. The first 446 was built with snap fast. The latter 4 digit machines had engines spinning the other direction. Luckily, the group of attachments you need are the most common. Attachments from 200 series also fit except for the sleeve hitch. The 400 series is longer. 3 points pop up on ebay from time to time. Expect to spend around 500 ish for one. Barneveld Implement seems to have a constant flow of stuff. They're in Wisconsin I believe.
Eric
Sent from my SPH-L720T using Tapatalk
#6 gardentractor1231 OFFLINE
gardentractor1231
  • 4 posts
Posted May 12, 2016 - 11:17 PM
I'm probably more interested in a sleeve hitch type set up but I'd need the hitch and lift for those. Can anyone help me out or point me in the right direction of what I'd need or anything.
#7 gardentractor1231 OFFLINE
gardentractor1231
  • 4 posts
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,170 Thanks
  • 5,768 posts
Posted May 13, 2016 - 07:33 AM
:welcometogttalk: :camera:
