brake on an 850
20 replies to this topic
#16 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 18, 2016 - 06:53 AM
Still sounds like something is binding somewhere
#17 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 18, 2016 - 12:31 PM
can anyone tell me what should be releasing from this exploded parts view. if I look under my 850 I'm guessing #175 and #178 are baked together and they are releasing fine from #179. Could #176 or #177 be stuck? I have never had this apart so I'm not quite sure how it works under there.
#18 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 18, 2016 - 01:23 PM
Number 179 should be "Free floating" between the two plates when the clutch is depressed, discs are backed on to 179
  • ClassicBolens said thank you
#19 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted May 18, 2016 - 01:35 PM
#178 is the larger friction disc ( Bolens part # 1714630 )
# 180 is the smaller friction disc ( Bolens part # 1717298 )
Both of these are bonded to the #179 pulley (sheave).
Two #181 Needle bearings ( Bolens part # 1185471 ) are a press-fit in the #179 pulley.  ...These bearings ride on the #182 spacer.
When the clutch pedal is pushed down, the #175 rear Clutch flange moves away from the #178 friction disc.
The #176 spring causes the pulley assy to move slightly rearward, away from the #183 front clutch flange.
The pulley assy now spins freely on the #182 spacer, and the #16 2driveshaft should not turn.
When the clutch is released, spring pressure from the large #164 spring compresses the two clutch flanges against the friction discs.
  • Bolens 1000 and ClassicBolens have said thanks
#20 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 18, 2016 - 09:17 PM
We liked under the tractor today, the pully assembly was stuck to the front friction disk. A couple whacks with a hammer and a brass punch and it was free. Now I have to return the battery to TSC, brand new and it won't turn the Wisconsin over with out assistance.
  • Bolens 1000 said thank you
#21 dmcjt850 OFFLINE
dmcjt850
  • 18 Thanks
  • 80 posts
Posted May 19, 2016 - 08:30 PM
Ok so it may not be the battery now. Going to try and polarize the start / gen.
