Can anyone figure out my intent here?
29 replies to this topic
#16 fonz3482 OFFLINE
fonz3482
  • 1,450 Thanks
  • 807 posts
Posted May 12, 2016 - 01:04 PM
What is the MTF?
Another place with a group of tractor crazy people talking about their addiction
  • Auburn David and Diesel1050 have said thanks
#17 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 12, 2016 - 01:55 PM
MTF used to be more for big tractors and related, BUT, just like the hobbie, has now drifted into lots more on GT's and other items. I'm on the MM forums at times and almost nothing goes on there or very slow at least. Has a good group for the MTD line of 990's and others. Power King, not so good, and Speedex about Non-existant!  They like the CUT and SCUT types quite a bit also.  The usual too much Green and Red big tractors there, like other places. It was once the best tractor forum on line, but has older version of the programs, not as easy to get around on as it is here, but still interesting.
  • Auburn David said thank you
#18 HANKG OFFLINE
HANKG
  • 6,597 Thanks
  • 3,530 posts
Posted May 12, 2016 - 05:29 PM
I can't figure out fuigure out. just chiding
#19 Mtypython OFFLINE
Mtypython
  • 372 Thanks
  • 351 posts
Posted May 12, 2016 - 05:54 PM
Gee and i thought it was gonna be a mini skidder for the for the wiscasset vacant building fair parade. Seriously you are always doin something interesting, want lots of pics
#20 nkaust OFFLINE
nkaust
  • 79 Thanks
  • 97 posts
Posted May 12, 2016 - 08:40 PM
sounds like a good project now you can go ahead and sell me your 2 stage blower lol
#21 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 13, 2016 - 05:23 AM
Haha, Nope! It will be on this thing for the winter!
Sent from my SCH-R970 using Tapatalk
#22 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 13, 2016 - 05:36 AM
Ok. So. Let me splain' my logic a bit. Going to be using parts from two 1250 large frames, a White GT-1855, a Bolens 850, and a Ford F-350 SD. Yep, you read that right. Going to move the factory frame rails, now the transaxle(s), will be more-or-less centered, front to back. As much as a 4x4 would be awesome, devising a transfer case system would be fairly difficult. Not saying I won't do it in the future, just not now. The frontmost transaxle will have the hydro pump removed, and a blockoff plate will be made. This will result in a free-spinning transaxle. Motor will mount in the location shown, and will use a double sheave pully, as well as one on the hydro pump, to run the drive system. Pivot has given me some trouble, that being said, I think I have a solution. Going to use a rear axle shaft from a 2006 F-350 turbodiesel, cut it down, and put it in a piece of very heavy-duty thick walled steel pipe, which will be welded to the front half (Maybe, any benefits to it being on the front or back half?) Axle will fit VERY snugly in this pipe, and will be held in with a "Collar" of sorts. Many grease fittings will be added to the pipe. Steering will be mechanical, utilizing the factory Bolens 1250 column and a VERY long tie rod, to a "V" shaped piece, which will face the back half of the machine, and pivot. There will be two HD tie rods off this plate to turn the machine. I may T into the hudraulics at the pump, and add a rear lift remote. Operator's area will be in the frontmost part. Not really sure of the design yet.
Edited by Diesel1050, May 13, 2016 - 05:37 AM.
  • KennyP, toppop52 and Paulgo have said thanks
#23 MH81 OFFLINE
  • 29,979 Thanks
Posted May 13, 2016 - 06:46 AM
Always lots of engineering in a project like this.
Any way to use hydraulics to drive the fronts?
#24 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 13, 2016 - 06:56 AM
Thought about that. Would need a monster pump to do that I think....and a very expensive hydraulic motor. I also obtained 4 new 30x9x15 tires for it!
#25 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 13, 2016 - 07:46 AM
Sadly..I have all kinds of pumps and motors..One day I will build something cool with all the hydro crap I have around here....Just not sure what it will be.Necessity will dictate as always.
#26 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted May 13, 2016 - 08:20 AM
Very cool! watching with anticipation....
#27 toppop52 ONLINE
toppop52
  • 5,545 Thanks
  • 4,906 posts
Posted May 13, 2016 - 10:22 AM
Cool!
#28 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 14, 2016 - 09:42 AM
Update! With pictures!!!! So, got the complete tractor tore down. Going to do the same to the parts rig next. Who likes my frame idea? Pretty slick, huh?81d598ecc8dd287ebe7a7312291547d5.jpg6c890e55d333f83f2f2223c2b4f6e20c.jpg6074704ced734cfe27369cc559d8fa1d.jpg
#29 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 16, 2016 - 08:01 AM
Stupid question time! Thinking of how I want to run stuff, could I reverse the transalxle, so input shaft is facing backwards, and run it that way? Would the reverse (Now foward) speed be ajustable so it would be as fast as foward normally? This would allow for the motor to be connected to the transaxle via a shaft, and would also make it easier to run the PTO.
Edited by Diesel1050, May 16, 2016 - 08:05 AM.
#30 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 17, 2016 - 05:00 PM
It's aaaaaallllll good! Decided to put the motor on the front half, for ease of running the PTO. Pics included. This was a rough mockup, I probably will use the Bolens fenders and foot rests uploadfromtaptalk1463522442240.jpg uploadfromtaptalk1463522409888.jpg
  • Auburn David and Paulgo have said thanks
