GT20 Shuts off when engage pto
12 replies to this topic
#1 johnpamac OFFLINE
johnpamac
  • 9 Thanks
  • 15 posts
Posted May 11, 2016 - 03:59 PM
Just bought 2 Ariens GT20's and having electrical issue with one.  When I try to engage either front or rear pto the tractor shuts off.  The switch at the shifter works, as does the switch on the seat.  Any direction as to what I should be looking for?
#2 Gillis.jim ONLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted May 11, 2016 - 04:05 PM
Check the seat switch relay
Edited by Gillis.jim, May 11, 2016 - 04:15 PM.
#3 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted May 11, 2016 - 04:13 PM
Not knowing the condition of the tractor, is there a chance that they corroded or seized up? Good chance the seat switch failed since it is happening on the front and rear.
Edited by shorty, May 11, 2016 - 04:14 PM.
  • Gillis.jim said thank you
#4 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted May 11, 2016 - 04:45 PM
There's a lot more that just a few switches and relays involved.
I'm going to suggest going through the electrical troubleshooting portion of the manual and an electrical schematic for that model. Before forking out $90 for a new time delay module. Unless your handy with a soldering iron. Then I'll reference my diy time delay and you can build one yourself.
  • Auburn David said thank you
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 11, 2016 - 05:33 PM
Do share.
#6 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted May 11, 2016 - 05:50 PM
http://gardentractor...y/?fromsearch=1
#7 johnpamac OFFLINE
johnpamac
  • 9 Thanks
  • 15 posts
Posted May 11, 2016 - 06:30 PM
What's the method to checking seat relay? We have other Ariens but they have all been bypassed and I am not going to do that, this one is for my son to mow yards
#8 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted May 11, 2016 - 07:03 PM
Mine were bypassed when I got them too. I think it is a closed circuit so unplugging the switch and use a jumper wire. That is the easiest way I know to do a quick diagnoses.
Edited by shorty, May 11, 2016 - 07:05 PM.
#9 johnpamac OFFLINE
johnpamac
  • 9 Thanks
  • 15 posts
Posted May 11, 2016 - 07:11 PM
I just looked at the ignition switch and noticed that at one point a wire did short.  There is a single pole connecter and a 5 pole connecter for the ignition switch.  A wire from the group of 5 is scorched.  Would a faulty ignition switch give me this issue?
#10 Wm McNett OFFLINE
Wm McNett
  • 127 Thanks
  • 170 posts
Posted May 11, 2016 - 07:19 PM
Starting on page 19 is the electrical, Starting on page 52 is the electrical troubleshooting
http://apache.ariens...als/000127A.pdf
My ignition switch fix
http://gardentractor...s/?fromsearch=1
#11 johnpamac OFFLINE
johnpamac
  • 9 Thanks
  • 15 posts
Posted May 17, 2016 - 06:20 PM
I was not able to track down the issue but I dropped tractor off to be looked at. When i get it back I will report back.
#12 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 17, 2016 - 08:54 PM
NOOOOO...say it aint so!!!!
#13 johnpamac OFFLINE
johnpamac
  • 9 Thanks
  • 15 posts
Posted May 22, 2016 - 09:46 AM
OK GT 20 is fixed.  Both PTO diodes were burned out along with the ignition switch. Great Ariens shop near me took care of it
  • olcowhand said thank you
