John Deere Gator AMT 626
15 replies to this topic
#1 SearsYellow OFFLINE
SearsYellow
    Mower Extraordinaire
  • 506 Thanks
  • 595 posts
Posted May 10, 2016 - 09:19 PM
I am stumped and I cannot figure it out. I have a 1989 John Deere AMT 626 with a FE290 Kawasaki. I am not getting fire at the plug. I can hook up a inline spark tester and I have fire. I pull the plug and stick it to the side of the block of the engine and no fire. I bought a brand new coil and connector for the plug.
Any Ideas?
  • hamman said thank you
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted May 10, 2016 - 09:47 PM
new plug?
#3 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,418 posts
Posted May 10, 2016 - 09:54 PM
Bad spark plug wire?
#4 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 10, 2016 - 09:59 PM
Ingniter!!!!!!!!!!!!!!!!!!!
Sent from my SCH-R970 using Tapatalk
  • jpswift1 said thank you
#5 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 10, 2016 - 10:08 PM
I have looked for a igniter and I can not pin point one for this engine. Yes the coil is brand new and the plug cap. I'd be more than glad to buy the igniter if I can find the part.
#6 jpswift1 OFFLINE
jpswift1
  • 793 Thanks
  • 616 posts
Posted May 10, 2016 - 10:35 PM
Yes, Diesel1050 is right!  It's the igniter.  I have a Deere AMT626 and torn a few of them apart, including the FE290D engine and that's the issue.  It's a little (about 1" by 1") silver box that sits on the governor/throttle arm assembly with one flat prong on it for the wire to plug onto.
#7 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 11, 2016 - 09:46 AM
I went and bought the igniter at the JD place today..... 79 dollars later... Hopefully this works. uploadfromtaptalk1462977994640.jpg
Sent from my D6708 using Tapatalk
#8 jpswift1 OFFLINE
jpswift1
  • 793 Thanks
  • 616 posts
Posted May 11, 2016 - 10:33 AM
I went and bought the igniter at the JD place today..... 79 dollars later... Hopefully this works. attachicon.gifDSC_0113.JPG
Jeeze!  That's expensive for that little part...........probably just because it's green and yellow with a picture of a Deer on it, ugh!
Let us know if it works.  I didn't even think the igniter would be available still.
#9 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 11, 2016 - 11:02 AM
So far.. No good. I actually had to recharge the battery due to the excessive cranking. At this point and time I'm take the carb off and see if there is something I missed. I put a brand new fuel pump, gas line, filter, coil, spark plug, plug cap, igniter, battery and cleaned the carb 3 times. There's something I'm missing.
#10 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted May 11, 2016 - 12:14 PM
Do you have spark now?
#11 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 11, 2016 - 12:39 PM
Nope.
#12 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted May 11, 2016 - 12:42 PM
No spark correct, then the ignition relay needs to be checked, it supplies power to the ignition system.
#13 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 11, 2016 - 12:43 PM
Where is that?
#14 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 11, 2016 - 08:10 PM
Good news. There was a plastic piece under the old igniter so I left it there. More than likely the igniter has to be grounded or else it won't work. I took the plastic piece out and it fired right up. Now for some reason the thing is flooding itself out.
#15 SearsYellow OFFLINE
SearsYellow
  • 506 Thanks
  • 595 posts
Posted May 31, 2016 - 09:01 AM
I have another question for all of you. I am looking to buy a new Carb for my the AMT. On ebay there is some that's 18-80 bucks. What's the main difference between all of them?
