noisy 214 transaxle
23 replies to this topic
#16 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 27, 2011 - 02:08 PM
Lary
Have you checked the transmission section of the manuals area. There is a 2300 series repair manual and a parts list. I'm not sure how close this will get you to the 2333 in your 214. You can also go to jdparts.com and see if they have the parts diagrams there.
#17 mehs1970 OFFLINE
mehs1970
  • 3 Thanks
  • 20 posts
Posted August 27, 2011 - 05:22 PM
Got it.
Thanks Brian. The 2300 manual appears to be the same as the section in the larger Peerless manual, which I had already downloaded.
#18 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,552 posts
Posted August 27, 2011 - 06:20 PM
The 4 speed peerless used in the 200 series is the same 4 speed used in the RF110/112 and Flat fender 110/112. The only difference is the pulleys and other items that attach.
Take my advice on this - fix it before it gets worse. I am in the process of a transaxle swap because I lost teeth on 4 different gears when it the transaxle jammed in 3 and reverse. I went with a used transaxle to save money. One of the main cluster gears costs $140 from Deere. :bash:
#19 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 27, 2011 - 06:47 PM
140$ Ouch that bites!! A used tranny would no doubt be cheaper as well as easier if there is much damage.
#20 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted August 27, 2011 - 10:13 PM
I wouldn't recommend buying an used transmission - it may be the same or worse condition than what you got. The problem lies in just what we see here, driving the tractor until severe damage is done. Buying an used transmission isn't the answer as that transmission may have went through a similar scenario, and probably did. Best way to go is to fix the transmission you got and you will get another 30 to 40 years service. You will have good new parts. And repairing these transmissions are relatively easy.
BTW, WFM is weekendfreedommachines.com - one of the oldest John Deere lawn and garden site on the web.
Edited by Tmo, August 27, 2011 - 10:20 PM.
#21 mehs1970 OFFLINE
mehs1970
  • 3 Thanks
  • 20 posts
Posted August 28, 2011 - 09:02 PM
TMO, what takes you 20' takes me 4 hours. I got the transaxle off the tractor and split it open. So far, it looks like I need to replace the smallest gear of the 3 gear cluster.
The weekend freedom machines site is very helpful. After spending some time there, I feel like I know enough to do this.
Thanks for your help.
Larry
#22 mehs1970 OFFLINE
mehs1970
  • 3 Thanks
  • 20 posts
Posted August 29, 2011 - 12:56 PM
So I definitely need to replace the 3 gear cluster and the shifter spring/balls. I will probably replace the reverse idler gear, since the bevels are somewhat banged up. I'm looking at $140 for the cluster, another 12 for the idler gear, plus gaskets and seals.
#23 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,552 posts
Posted August 29, 2011 - 03:21 PM
Care to post some pics of the damage?
#24 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 29, 2011 - 06:23 PM
That doesn't sound bad, around 200$. I thought the gears were 140 each.
