Rims on Gt 20
5 replies to this topic
#1 tom tractor OFFLINE
tom tractor
  • 206 Thanks
  • 205 posts
Posted May 10, 2016 - 06:36 AM
Would the rims from a john Deere zero turn fit onto a Gt20? Do the brakes require special rims? Photos of The JD rims are attached.
#2 Delmar OFFLINE
Delmar
  • 2,525 Thanks
  • 2,544 posts
Posted May 10, 2016 - 06:42 AM
Is that an Ariens GT20?  if so they should fit.  Maybe you should measure the bolt spacing and center hole of each first to be sure.
#3 tom tractor OFFLINE
tom tractor
  • 206 Thanks
  • 205 posts
Posted May 10, 2016 - 06:47 AM
Yes it is an Ariens Gt2O. Currently the tractor has 10.5 wide tires. The JD tires are 8.5. Which one would give better traction?
#4 Delmar OFFLINE
Delmar
  • 2,525 Thanks
  • 2,544 posts
Posted May 10, 2016 - 07:02 AM
the 10.5 is a bigger footprint....for traction I would use ag tires instead of turf tires
#5 shorty ONLINE
shorty
  • 4,488 Thanks
  • 4,628 posts
Posted May 10, 2016 - 08:47 AM
The 8.5 will give you more weight per surface area. If it gives more traction depends on where you are running it. I tried it one winter in snow to go with a narrower tire. I didn't like it and went back to the 10.50
  • 1964Deere said thank you
#6 1964Deere OFFLINE
1964Deere
  • 248 Thanks
  • 292 posts
Posted May 10, 2016 - 11:31 AM
The brake is all contained and doesn't have anything to do with the rim. Should fit fine. Depending on your operation depends on what kind of tires I would suggest. I have both Ag's & turfs for my Ariens, just incase ;)
  • Gillis.jim said thank you
