Won't turn over fast
3 replies to this topic
#1 fedora OFFLINE
fedora
  • 48 Thanks
  • 55 posts
Posted May 10, 2016 - 06:31 AM
Hello all,
Have a co-worker that has a 2013 21hp(B&S) Craftsman lawn tractor that won't turn over fast enough.
He put a new battery in it, then tested the new battery, its a little weak on the load tester, but should turn it faster. He bypassed the solenoid with a jump pack, and it turned over fine, so he changed the solenoid, but it still doesn't turn over fast enough. He also checked all his battery cables as well...Any ideas?
Thanks,
fedora
#2 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 10, 2016 - 06:44 AM
I would check for a bad ground, especially if he has changed the terminal connector with one of those cheap ones
#3 CRFarnsworth ONLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted May 10, 2016 - 07:50 AM
Try resetting the valves.
  • toppop52 said thank you
#4 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted May 10, 2016 - 08:15 AM
Yep, I know you said bypassing the solenoid worked, but using heavier wire to bypass may be the reason you got more power. Adjust the valves to .005 and watch it fly.
