Craftsman lwanmower pullie switch
9 replies to this topic
#1 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 09, 2016 - 03:57 PM
Hello just got a crafts man riding lawnmower need some help to know how to switch the pullie and need help to know what model it is the cereal number is 502.602111 looked it up found nothing
  • emmauo3 and virgilcx60 have said thanks
#2 James Bosma OFFLINE
James Bosma
  • 1,337 Thanks
  • 657 posts
Posted May 09, 2016 - 04:10 PM
If you can post a picture of your Craftsman tractor it be a great help
Plus the manuals are most likely already in the manual section
You can download 3 manuals aday
  • Auburn David and Lawnboy have said thanks
#3 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 09, 2016 - 04:12 PM
Thanks I will post a picture one sev
#4 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 09, 2016 - 04:14 PM
Ok thanks I will post a picture in a sec
  • hamman said thank you
#5 glgrumpy OFFLINE
  • 8,622 Thanks
  • 7,926 posts
Posted May 09, 2016 - 05:56 PM
Kinda Vague here on your request. WHAT exactly are trying to do?  Drive pulley,  mower deck or drive to it?? Best to find a parts manual and a part number in it if you can and show diagram pictures with part you want circled??  Just want to know how to remove?  Pin in it?  set screw?  Just weathered on and gonna be hard to pull?   Are you soaking it in PB blaster or something if that is what you want?  Need more info.
  • hamman and Lawnboy have said thanks
#6 James Bosma OFFLINE
James Bosma
  • 1,337 Thanks
  • 657 posts
Posted May 09, 2016 - 08:09 PM
I did abit of reseach and belevie he has a LT 11
From what I have found out it was made by Murray and manual is real hard to find and not posted online
The serial he posted would be correct but is really no help to sears as other people has stated in other forums
I think it looks like this
Was wondering what pulley aswell but first was going to dertime which model he has to help us help him
  • Lawnboy said thank you
#7 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 09, 2016 - 09:29 PM
Ok I did some research as well the motor is a 1983 lt11 look up 1983 craftsman lt11 the first picture that comes up thats just like mine I dont know how to post a image so I. So sorry and looking to do a drive pulley
  • James Bosma said thank you
#8 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 09, 2016 - 09:33 PM
Got it
#9 James Bosma OFFLINE
James Bosma
  • 1,337 Thanks
  • 657 posts
Posted May 10, 2016 - 04:53 PM
Is there a bolt on the end of shaft if so remove bolt and pulley may slide right off, if not
Is there a bolt or set screw in the shoulder area of the pulley rotate engine to check all the way around  if not
Look at the pully in the v part, rotate engine and see if you can find  a hole, If there is a hole there is a set screw in there, use a proper size allen key to remove the set screw.
Most pulleys are keyed and set screws are usually in this area
#10 Lawnboy OFFLINE
Lawnboy
  • 7 Thanks
  • 12 posts
Posted May 11, 2016 - 02:37 PM
Thanks so much
