Homemade or factory tractor
6 replies to this topic
#1 hddlh OFFLINE
hddlh
  • 46 Thanks
  • 80 posts
Posted May 09, 2016 - 07:55 AM
Found this for sale.  It looks homemade, but could it be a factory made tractor?  Any thoughts?00c0c_j6wD13XFlFs_600x450.jpg
  • boyscout862 and Auburn David have said thanks
#2 boyscout862 ONLINE
  • 13,442 Thanks
  • 9,391 posts
Posted May 09, 2016 - 08:07 AM
Hard to tell by just that one pic. That is a wierd rear wheel. Good Luck, Rick
#3 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,103 Thanks
  • 1,897 posts
Posted May 09, 2016 - 08:13 AM
I'm going to vote for home made.
It looks to have a Ford Model-A steering and rear axle so it probably has a Model-A transmission also.
It is an unusual design with  the Wisconsin engine in the back.
I'm assuming there is a jack-shaft from the engine running up to the front of the transmission with possibly a V-belt clutch assembly ?
Edited by jdcrawler, May 09, 2016 - 08:15 AM.
  • Gtractor said thank you
#4 John Arsenault ONLINE
John Arsenault
  • 2,848 Thanks
  • 1,298 posts
Posted May 09, 2016 - 09:19 AM
That rear wheel screams monster garage to me. I see a spoked rim with a brake drum (very common) attacked to a tractor wheel using welded splines to where it looks to be the outer area of where a tire would mount.
Monster...monster garage.
#5 John Arsenault ONLINE
John Arsenault
  • 2,848 Thanks
  • 1,298 posts
Posted May 09, 2016 - 09:21 AM
Ooooops no it screams Junk yard wars.....I did like monster garage to...haha
#6 toppop52 OFFLINE
toppop52
  • 5,458 Thanks
  • 4,864 posts
Posted May 09, 2016 - 09:32 AM
Gotta be a one off, front wheels and carriers look like modified zero turn stuff, cool rear wheels, never saw any like it.
#7 jtrojek OFFLINE
jtrojek
  • 1,133 Thanks
  • 581 posts
Posted May 09, 2016 - 10:38 AM
I'd say homemade.  Someone had emailed me about it through my website before they listed it.  They sent me a ton of pictures.  The front axle looks like a Handiman R/T.  There are some other cast parts that are from something or other as well.  There does look to be some model A stuff in there.  I had wondered if it didn't originally have a model A engine, and then the Briggs was fitted on at a later date.
  • tater195 said thank you
