Fence post and small brush puller/grabber
8 replies to this topic
#1 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted May 08, 2016 - 04:57 PM
Got this idea from off the net. I made mine fit onto the bucket of my Kubota rather then using it on the 3 pth. I don't like looking backwards and doing stuff because of how my neck bothers me now. I made mine just from some scrap that I had laying around didn't buy anything except for some bolts. My first try didn't work out to good because what was happening is that one side would stay up and the other side would go down.My solution was to link the two jaws together by using a sliding tee. The fixed part is 1" sq tubing and the sliding one is 3/4" sq tubing that fits inside the 1".I used some 9/16" rod for the cross tee's and on each end I used some 3/4" flat bar welded onto the ends of the rods.The 3/4" flat also keeps the sliding part from wanting to move sideways. I've pulled out some smaller trees etc: and pulled out one fence post just to show that it does work.I made this so that I can pull out some brush that growing up into my fence.Guess if I ever wanted to pull up fence posts I could use it for that as well. The pics should give you a pretty good idea of how it works.One thing about this is that I don't need hydralics to close the jaws together.
  • DH1, coldone, hamman and 14 others have said thanks
#2 KennyP ONLINE
  • 38,312 Thanks
  • 45,904 posts
Posted May 08, 2016 - 05:04 PM
Should work good!
  • massey driver and boyscout862 have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted May 08, 2016 - 05:22 PM
Very well manufactured!
#4 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted May 08, 2016 - 05:52 PM
Looks very handy.
#5 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted May 08, 2016 - 06:31 PM
look slike it should work great.
  • massey driver said thank you
#6 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted May 08, 2016 - 06:58 PM
Well made looks handy to have. Does the top of the jaws grip the post or tree good like you have it. I have several fence posts to replace & was going to use the normal chain wrapped over a car wheel set in front of the post to force it upward. This looks like something I would like to make also.
#7 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted May 08, 2016 - 07:14 PM
at first it didn't grip to great. I ended up running some beads of weld length  wise along the gripping edge ,then used my angle grinder to cut grooves along the beads. So now I have 3 teeth edges to grab onto stuff. It grabs pretty good . It works good now so next is going to be putting some paint onto it.
  • Sawdust said thank you
#8 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,142 posts
Posted May 08, 2016 - 08:45 PM
The sliding tee was a good remedy.  Thanks for the pics and description.     Rick
  • massey driver and Sawdust have said thanks
#9 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted May 08, 2016 - 09:08 PM
Wow fantastic!! Love the idea
