It lived then died
10 replies to this topic
#1 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted May 08, 2016 - 01:21 PM
So had the big ten going for two minutes everything seemed fine then she died on me and couldn't get her reifred. The engine code is partial and hard to read so does anyone know a code for that engine I can use to get a carb kit and plug with? Or anyone have any good advice it can't be anything serious I'd imagine cause she ran good
#2 Bolens 1000 ONLINE
  • 15,427 Thanks
  • 18,283 posts
Posted May 08, 2016 - 01:25 PM
Did you check to see if you lost spark?
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted May 08, 2016 - 01:29 PM
3 things in this world that are nearly impossible to keep clean and free of debris:
No particular order.
MH81's glass and aluminum recycling container.
Uncle Willie's son, Heath.
A Briggs updraft carb.
EDIT: 5
The third stall of my garage.
Nutndun's email account.
EDIT: 6
glgrumpy's whole garage
EDIT: 7!
DougT's whole yard..
  • Bolens 1000, Gtractor, MH81 and 2 others have said thanks
#4 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted May 08, 2016 - 01:31 PM
So you think it just fouled up the carb them?
#5 Bolens 1000 ONLINE
  • 15,427 Thanks
  • 18,283 posts
Posted May 08, 2016 - 01:35 PM
Could be:
If its the standard 3 bolt  flo jet carb this should be the kit
http://bolenspartsan...-295938-394693/
EDIT:
You can use either plug you prefer:
http://bolenspartsan...-and-s-engines/
http://bolenspartsan...mon-on-b-and-s/
  • Orange appeal said thank you
#6 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted May 08, 2016 - 02:22 PM
Thanks I'll try those. Hope that does it do I can drive my little big ten she ran soo good too I have hope
#7 boyscout862 ONLINE
  • 13,552 Thanks
  • 9,427 posts
Posted May 08, 2016 - 06:15 PM
Problems with my B10 are: water in gas, corroded points, and a short of the wire that goes to the points. The wire often wears at the cover and shorts to it. Good Luck, Rick
BTW when rebuilding those carbs, read the directions twice before trying to work on it.
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,117 Thanks
  • 10,188 posts
Posted May 08, 2016 - 08:14 PM
3 things in this world that are nearly impossible to keep clean and free of debris. . . . .
The amount of info you collect on the members could put you on the BLACKLIST.
  • MH81 and Cat385B have said thanks
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted May 08, 2016 - 08:18 PM
I help make that list.
Anyway, 'Rich' is spelled in such big letters that there is hardly room for anyone else....
#10 ACmowerguy OFFLINE
ACmowerguy
  • 459 Thanks
  • 387 posts
Posted May 08, 2016 - 08:58 PM
Could be:
EDIT:
The Big Ten originally had a model 243431 Briggs engine which has a 4 bolt carburetor.
#11 UncleWillie OFFLINE
  • 16,254 Thanks
  • 8,971 posts
Posted May 09, 2016 - 05:06 PM
You should see him right now after a full afternoon of outdoor playing and helping work on a truck.
  • MH81, Cat385B and Orange appeal have said thanks
