Winco generator for $20
14 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 08, 2016 - 08:02 AM
Bought this Winco generator for $20 the other day. Anybody have any ideas on year it was made?
Has a no spark issue. Got any ideas on ptoblem?
Thanks
#2 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted May 08, 2016 - 08:05 AM
Bad/dirty points, bad condenser, bad coil?
Mice?
Edited by KC9KAS, May 08, 2016 - 08:07 AM.
  • boyscout862, HANKG, adamjd200 and 1 other said thanks
#3 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,989 Thanks
  • 2,480 posts
Posted May 08, 2016 - 08:15 AM
You can get an idea of its age through the B&S engine numbers.
If you post all of the B&S Model - Type - Serial (or Code) Numbers, we can help.
  • boyscout862 and coinman66 have said thanks
#4 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 08, 2016 - 08:23 AM
Ahhh ok. Are the B&S numbers on the flywheel shield? Was this a decent deal for $20?
#5 boyscout862 OFFLINE
  • 13,560 Thanks
  • 9,434 posts
Posted May 08, 2016 - 08:24 AM
It looks like it has the little light on top of the generator. That was popular in the 50s and 60s. I'd just pop the flywheel off, clean and gap everything and see if it sparks before you put the shroud back on. Good Luck, Rick
I'd have paid $20 for it.
Edited by boyscout862, May 08, 2016 - 08:38 AM.
  • coinman66 said thank you
#6 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,989 Thanks
  • 2,480 posts
Posted May 08, 2016 - 08:48 AM
Depending on the model of the B&S engine, the numbers would be stamped into the flywheel shroud, or into a plate affixed over the cooling fins at the back of the engine.
Again, depending on the model of the B&S engine, the numbers could be stamped in any of 4 places on the flywheel shroud, so look carefully.  ...Some were stamped on the flat part of the shroud near the spark plug, some were stamped on the flat part of the shroud behind the air filter, some were stamped on the front of the shroud above the round opening, and some were stamped on the rounded part of the shroud on the carb side.
  • HANKG said thank you
#7 dodge trucker OFFLINE
dodge trucker
  • 2,827 Thanks
  • 3,460 posts
Posted May 08, 2016 - 10:54 AM
looks like one that I used to have, little light on top and all. Mine had a model 14 cast iron engine on it. That thing was HEAVY!
#8 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 08, 2016 - 11:13 AM
Yah this thing weighs a metric ton!
#9 Bill 76 OFFLINE
Bill 76
  • 2,013 Thanks
  • 1,207 posts
Posted May 08, 2016 - 02:00 PM
For $20 dollars you got ripped off--but being a kind hearted person I will give you $20 for it just so you have a good day. :D
#10 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 08, 2016 - 03:07 PM
So when I get this running and maybe sell it. What kind of price are they going for?
#11 DougT OFFLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
Posted May 08, 2016 - 05:55 PM
$25.00  :D
#12 adamjd200 OFFLINE
adamjd200
  • 2,094 Thanks
  • 2,207 posts
Posted May 08, 2016 - 08:53 PM
Mice?
Never seen one that bad, wow!
I have a generator from the 50's, but it is a Kohler, most from that era had a light on top that I have seen.  Make sure you clean the magnets and bottom of the coil tat they pass under as well, I usually use sandpaper for this.
Here's a pic of my Kohler, and yes all old generators are heavy.
#13 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 09, 2016 - 02:23 PM
Ok here is what I think I'm seeing. ID tag is in a tuff spot. 14FB 202589 364589
5
The F could be a 5.
So I'm thinking 1964 on the build date?
#14 DougT OFFLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
Posted May 09, 2016 - 04:03 PM
It's a model 14. The F stands for flanged output side of the block and the B stands for bearing instead of bushing on the output. That engine wouldn't have a code. It would be model-type-serial or model-serial-type. I can't remember which way they were listed. If the last number is the serial, it would be July 57. If the second number is the serial it would be Jan 54.
#15 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted May 09, 2016 - 06:27 PM
Looks like I got an oldie then. Maybe I will restore it to original blue color and get some decals. Thanks for info Doug!
