Kinkade Second generation Garden Tractor Info Needed
20 replies to this topic
#1 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 07, 2016 - 09:01 AM
I just got my second gen Kinkade running after almost 2 years searching for a good magneto, so I'm looking forward to getting it completed.
If anyone can help, I need some photos or info on how the fuel tank is mounted on the two supports with the right angle bends on the ends. I suspect that some pieces of wood go in there between the tank and the supports.
I also need some photos or info on how the caster wheels were constructed since mine were almost completely rusted away. It appears that they were made of some very light gauge sheet metal. Some photos of originals would be great so I could try to duplicate them as closely as possible. I doubt I would ever find some original wheels.
Any help would be greatly appreciated!
Mike :wave:
Edited by Junkologist, May 07, 2016 - 09:04 AM.
  • LPBolens, IamSherwood, Cvans and 9 others have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 07, 2016 - 09:57 AM
That thing is cool!
  • Junkologist said thank you
#3 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted May 07, 2016 - 11:10 AM
:thumbs:  :thumbs:
#4 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted May 07, 2016 - 05:36 PM
I cant give you any info, but like the others before me I can only give props! Very, very nice machine! :)
#5 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 08, 2016 - 11:10 AM
Thanks all for the kind words. :wave: I'm starting to feel like I have the only one out there, but I know that's not true.
Hey DougT, you got one of these squirreled away over there??
#6 Columbia236 ONLINE
Columbia236
  • 356 Thanks
  • 126 posts
Posted May 08, 2016 - 03:33 PM
:D I  had one but I sold it
#7 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 08, 2016 - 06:59 PM
From what I can remember, it was in exactly the same state of disrepair as the one I have.  :D  :D
  • Columbia236 said thank you
#8 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted May 08, 2016 - 08:32 PM
I'm in about the same shape. I don't have the definitive answer. I would suspect rubber before wood but don't know for sure. Do you have a pic of what was left of the wheel?
#9 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 08, 2016 - 08:51 PM
Doug,
I just figured wood since the Walsh and Standard tractors I have laying around here also have small wood saddles under the tanks. The major difference being that those have a continuous steel frame under the tank lengthwise where the Kinkade only has the small right angle bends on the ends of the supports.
I literally only have the very centers of the caster wheels left, which look like big flat washers at this point, so they offer no insight as to how the wheels were constructed. I could very easily make some wheels of my own design, which I may end up doing if nobody can offer any info on the originals.
#10 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 08, 2016 - 08:57 PM
Here's a photo of the wheel hub. All that's left of the actual wheel is sandwiched in the center.
#11 Alc OFFLINE
  • 7,240 Thanks
  • 7,586 posts
Posted May 09, 2016 - 05:55 AM
glad to hear you got it running .I remember seeing one at a show near wherr member earth grinder was showing he might have some info for you god luck Al
#12 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 09, 2016 - 07:32 PM
Something else I'm wondering about on this Kinkade is the exhaust. There was nothing on this tractor when I got it. I'd like to know if these had a cast iron turn out piece bolted on like the Walsh and Standard tractors, or did it have a straight exhaust pipe bolted on like my Kinkade K models have?
Here's a photo of where the exhaust bolts to the cylinder.
#13 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted May 10, 2016 - 07:00 AM
I tried to re-educate myself on gas tank mounting last night. There were more without anything between the tank and mount than there were with, One had what appeared to be the heavy red fiber like they make the fiber washers from. Another had what looked like hard rubber or maybe a piece of leather. There was a K that had something thicker but I couldn't get close enough to tell.
I don't remember any trailing wheels with grease cups on the hub. There is a K with a solid stamped wheel. I don't think I have any Kinkades with a bolt on pipe flange. Wish I could find the pics when I got my second gen. It was real rusty and rough but may show something. It's been apart too long!
#14 Junkologist OFFLINE
Junkologist
  • 29 Thanks
  • 13 posts
Posted May 10, 2016 - 07:52 PM
Here's some photos of the exhaust pipes and one of the wood tank saddles on my K model Kinkades. Those wheel hubs with the grease cups are original. The image of the tractor on the cover of the reprint manual I have shows the wheels with grease cups.
#15 DougT ONLINE
DougT
    Dog Approved
  • 7,117 Thanks
  • 5,080 posts
Posted May 10, 2016 - 08:43 PM
One of the first gen Standards has a pair of dolly wheels that looks like a single disc blade. I figured they were non original. They do look like the ones in the pic. Maybe they are original? I don't think they have grease fitting though. the only other ones I've ever seen solid were the stamped steel ones. They were stamped fairly square with a 3/4 to 1 inch rim face. They were only about 1/16-1/8 thick. I can't really tell if the ones in the pic have a rim face or not. I notice it has the later oil fill like yours. Does yours have the cast carb or is it aluminum/potmetal?
