Small square bale chopper
6 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,628 Thanks
  • 1,496 posts
Posted May 05, 2016 - 10:37 AM
My dad has an old bale chopper from eons ago... I want to repower it, to use it to chop and/or grind brush green grass wood shavings and straw.
Brush would be no bigger than 1".
Anyone think this would work?
I plan on making compost out of the chopped material.
I'll make a video of the whole thing...
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 05, 2016 - 11:10 AM
:camera: Please
  • Greasy6020 said thank you
#3 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,421 posts
Posted May 05, 2016 - 11:45 AM
If it is the type that I have used, the knives won't take it. They used a knife blade similar to a haybine.
Can you get a pic of the knives? I think that would be the deciding factor.
#4 Greasy6020 OFFLINE
Greasy6020
  • 1,628 Thanks
  • 1,496 posts
Posted May 05, 2016 - 12:10 PM
yes, they look exactly like haybine knives... probably the used knives from the haybine...
any ideas to replace knives with something more durable?
Edited by Greasy6020, May 05, 2016 - 12:10 PM.
#5 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,421 posts
Posted May 05, 2016 - 02:37 PM
The fixed blade on a spinning drum idea is similar to a chipper that a tree service would use. I think they use a round carbide tooth. Also a shredder with flail type knives, like a Mckissic, would work excellent for what you described. I hooked my son's up last year for fall cleanup. It did very good with branches leaves and grass.
Edited by shorty, May 05, 2016 - 06:31 PM.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 05, 2016 - 03:14 PM
I think more info is needed. B;ades? swinging hammers? What? How big is it?
I used to work building Farmhand Machinery. We built a Silage Blower, that would chop square baled. It had a conveyer to feed bales in. Now the flywheel was about 4 ft in diameter solid steel disc about 1 1/2 inch thick. bolted to that were paddles, with hammers on the end . And bolted to them was a disc with sicle blades that would shred the bales.  On the outside of the housing was a 1 inch pipe about a foot long to add water to the silage.  That pipe incidently was originally 2 inches long, till some fool stuck his finger in it to clear a plug and then sued the company? That machine took a minimum of 70 hp.
Incidently I tried to talk the chief engineer into scaling down a conventional hammer mill(we already built them) to sell as mulch grinders. He said there would not be enough market to even justify a market survey??  I wonder what he is building since the company went broke?
Edited by JD DANNELS, May 05, 2016 - 03:19 PM.
#7 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,421 posts
Posted May 05, 2016 - 06:37 PM
Think of umpteen haybine blades bolted to a drum. Built for shredding straw for bedding.
