* * * * - 4 votes
Soon my Precious....Sooooon
167 replies to this topic
#106 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 08, 2017 - 04:44 PM
Got the areas marked out for the recesses, cut the metal out and started to form the lips for the steps - got the large step and one of the small steps done.
Edited by 29 Chev, March 08, 2017 - 04:45 PM.
  • blackjackjakexxix, WrenchinOnIt, stiemmy and 1 other said thanks
#107 stiemmy OFFLINE
stiemmy
  • 2540 Thanks
  • 1830 posts
Posted March 08, 2017 - 05:08 PM
Looks great 29Chev!!!!!!
  • WrenchinOnIt and 29 Chev have said thanks
#108 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted March 08, 2017 - 06:22 PM
Can't wait to see how it comes out.
  • WrenchinOnIt, stiemmy and 29 Chev have said thanks
#109 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 08, 2017 - 07:14 PM
Me neither - not sure what it will look like yet.  Bending 16 gauge steel using hand tools is fun.
  • LPBolens, blackjackjakexxix, WrenchinOnIt and 2 others have said thanks
#110 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 09, 2017 - 05:50 PM
Double checked and found I that I was off about 1/4" in the lip placement for the inner lip on the large recess (not far enough away from smaller pads lip) so I bent the lip back down and formed the lip to make he stepped areas as part of the pads which seemed to work better and got the lip location within 1/8" of the original one.  Got the holes enlarged where the stepped pieces go and then got them tacked in place - will have to see how much things distort when they are welded.
  • olcowhand, blackjackjakexxix, WrenchinOnIt and 5 others have said thanks
#111 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 3768 Thanks
  • 2017 posts
Posted March 09, 2017 - 07:40 PM
Looking good!
#112 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 10, 2017 - 06:45 PM
Got the pads welded on and then ground the welds a bit.  The pan distorted a bit from the welding and it now rocks a bit when it is set on a flat surface - will see how bad it gets by the time I am finished welding and then see if I can level it out.  Got the hole locations marked out and pilot holes drilled - will have to double check them and make sure they are all in the correct locations before I enlarge them.
  • olcowhand, blackjackjakexxix, WrenchinOnIt and 3 others have said thanks
#113 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 13, 2017 - 05:08 PM
Got the holes drilled and added the anchors and nuts for the mounting bolts - used 1/8" x 3/4" wide flat steel and threaded the hole for 5/16" UNC and then installed a bolt and threaded a nut hand tight on the bolt and welded the nut to the flat steel.  I did another pass around the pads where they were welded onto the main section to add more strength but unfortunately this made the bottom distort more from the heat and I am not overly pleased with the results.  Will have to see if I can straighten it a bit - even though it won't be seen except when the seat is flipped up it just doesn't suit me the way it is.  May think about things for a day or two while winter gets another lick in - 12 degrees F today and supposed to be windy and white tomorrow - supposed to warm back up to freezing by the weekend.
  • olcowhand, blackjackjakexxix, WrenchinOnIt and 2 others have said thanks
#114 KennyP OFFLINE
  • 50116 Thanks
  • 52292 posts
Posted March 13, 2017 - 05:26 PM
I take it's supposed to be flat. There's a way to 'shrink' that, but I don't know exactly how!
  • WrenchinOnIt, stiemmy, 29 Chev and 1 other said thanks
#115 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 16, 2017 - 05:32 PM
It finally got close to the freezing point today so I tried to remove some of the distortion in the pan but after a little while I came to the conclusion that I was never going to be happy with the way the seat pan looked so I made a decision based on stubbornness and pride and started over with some new pieces of steel to make another pan.  This time I have decided to make the main section with the stepped parts and the three pad sections so they will join at the bottom of the step and the outer edge will be part of them in those areas - this will save on some welding and should let the welded areas look better when sanded.  Got the pieces cut out, steps bent and pads tacked in place.
  • Bolens 1000, olcowhand, WrenchinOnIt and 5 others have said thanks
#116 UncleWillie OFFLINE
  • 16500 Thanks
  • 9061 posts
Posted March 16, 2017 - 06:22 PM
nice
#117 ClassicBolens OFFLINE
ClassicBolens
  • 1525 Thanks
  • 516 posts
Posted March 16, 2017 - 08:38 PM
I thought it was looking pretty good, but sometimes we are our own best (or worst) critics.
  • Bolens 1000, LPBolens, WrenchinOnIt and 2 others have said thanks
#118 Dugmf12 OFFLINE
Dugmf12
  • 144 Thanks
  • 105 posts
Posted March 16, 2017 - 09:37 PM
You might call it stubornness and pride but I also see resourcefulness and creativity in play here.  This is a great thread and the seat pan recreation is really interesting to me.  I am enjoying you recreate something that looked improbable to me.  I am learning a lot and am impressed with your work and determination!  Great job.  It looks like  you solved the warping issue.  Keep up the good work :thumbs: !
#119 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 19397 Thanks
  • 6576 posts
Posted March 17, 2017 - 07:48 AM
If this was for my own tractor or if the seat did not tip up I might not be as fussy but given what this tractor has been through I want to do the best job I can.  It won't take much steel to fab up another one and now that I think I know how to construct it better it should go faster to make this one.  Since I already have the first pan made if the second one starts to distort I can stop and use the first one - I just would not feel right with this project if I did not try and make another one that was better.
Will see what this one looks like after I get the welding done - time will tell.
  • WrenchinOnIt, ClassicBolens, stiemmy and 1 other said thanks
#120 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5020 Thanks
  • 1203 posts
Posted March 17, 2017 - 03:17 PM
Stew like most of us when we are restoring a piece are our own toughest critic. Stew agreed to tackle this project last fall, he got the seat Feb 2017. What he got was more than I intended or more than he bargained for. He gave this immediate attention even thou as we all know is well into his tube-r restoration.
I continue to be amazed by his inventiveness and craftsmanship, he signed on for an upholstery job and instead has taken on a metal fabrication before he can even get started. I said it before and I'll say it again, this went to Stew because his work is OUTSTANDING, the Best ! I own four others seats by him and they are actually nicer than the OEM.
I don't know if this will be his crowning 'palmarius' or not , his seats for the 1000's & 900's werent to shabby :) to have this seat handmade by him is special,he has my gratitude and admiration for saddling this rusted out mess and making it new.
Thanks buddy.
Edited by WrenchinOnIt, March 18, 2017 - 10:36 AM.
  • LPBolens, HDWildBill, Newpaws493 and 3 others have said thanks
