AC 314H transmission
7 replies to this topic
#1 Leonard VanCamp ONLINE
Leonard VanCamp
  • 514 Thanks
  • 392 posts
Posted May 04, 2016 - 08:23 PM
I have a question for all Vickers guru's here, is there a pressure relief valve in a AC 314H transmission? My uncle got the bright idea to use his tractor to pull a log (18" dia by 16'-18' long pine log) and ended up getting the log stuck and the tractor isn't moving now. What kind of damage can I expect when I visit him this weekend and look at the tractor? I'm comfortable working on Sunstrands (JD 140, 316K and 420) but I have never messed with a Vickers setup.
  • rustyoldjunk said thank you
#2 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted May 05, 2016 - 12:11 AM
I would check for a broken axle tube first. That is the common weak spot in Simplicity and Allis transaxles.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 05, 2016 - 09:23 AM
Very weak point on these machines
#4 Leonard VanCamp ONLINE
Leonard VanCamp
  • 514 Thanks
  • 392 posts
Posted May 05, 2016 - 08:49 PM
Even with a broken axle tube wouldn't the tractor still move under power? I'm not to familiar with this transmission/rear end setup.
#5 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted May 05, 2016 - 09:50 PM
No,the axle tube transmits the power to the wheels on these transaxle.
#6 Leonard VanCamp ONLINE
Leonard VanCamp
  • 514 Thanks
  • 392 posts
Posted May 05, 2016 - 10:08 PM
Ok, thanks for the info!
#7 Leonard VanCamp ONLINE
Leonard VanCamp
  • 514 Thanks
  • 392 posts
Posted May 08, 2016 - 06:03 PM
Well, it looks like my uncle did break the axle tube. So the next question is how hard is it to replace, are we talking a complete trans mission tear down, or can I slide a replacement in without doing a complete tear down?
#8 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted May 08, 2016 - 11:01 PM
I believe that you have to split the case. Go over to Simpletractors and post in talking tractors. Lots of Simplicity Gurus there.
