1282 custom build
8 replies to this topic
#1 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted May 04, 2016 - 12:08 PM
I bought a 1282 a few month back that turned out to be a basket case, the rebuilt engine is junk and most of the tractor is beat and rigged together. I was going to part it out then decided to do a custom build, I started to rebuild the engine but the block is junk then I remembered I had a Kohler command 20hp with less than 400hrs on it from a newer cub so I decided to drop it in. I used the engine plate out of an 1811 and was givin the measurements of where to drill the new mounting holes. I got the plate drilled last night and I guess I'm pretty good at measuring because the engine bolted right up, once the engine was in place I measured the driveshaft and shortened the original to fit. I need to do some more measuring to make spacers for under the engine so the driveshaft is as straight as I can get it, once that's done I just need to hook up some wiring and the throttle/choke cables and it will be ready for a test spin. I have the ported rearend out of an 1811 I plan to put in so I can have hydrualic lift and front ports, once I have it all built the way I want it I will tear it back apart for sandblasting and paint.
Edited by olds45512, May 04, 2016 - 12:09 PM.
  • KennyP, Traill95, boyscout862 and 2 others have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 04, 2016 - 12:21 PM
Nice!!!
  • olds45512 said thank you
#3 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted May 04, 2016 - 04:21 PM
That's going to be a beast!
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,142 posts
Posted May 04, 2016 - 04:35 PM
That engine looks good in there!  :thumbs:        Rick ​
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted May 04, 2016 - 06:05 PM
Yea, kinda looks like a drag car, and IM DIGGIN IT!!!!!!
#6 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted May 04, 2016 - 06:46 PM
it sounds like a Harley with no exhaust, I'd mow my grass that way but I think my wife might protest. Lol
  • stiemmy said thank you
#7 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted May 04, 2016 - 07:00 PM
Lol
#8 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted May 04, 2016 - 11:34 PM
Going to be a great build Tim. Looking forward the progress pictures... :thumbs:
#9 olds45512 OFFLINE
olds45512
  • 1,339 Thanks
  • 677 posts
Posted May 05, 2016 - 01:59 PM
I'm excited to get it done but trying not to rush it so it turns out nice, I plan to get it together and mow with it for the rest of the summer to work out any bugs then pull it apart to paint it over winter.
Edited by olds45512, May 05, 2016 - 01:59 PM.
  • Auburn David said thank you
