JD 165 Hydro "Little John"
302 replies to this topic
#31 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 25, 2016 - 09:29 PM
I noted the lack of lock washers on many of the bolt fasteners. Not sure if I should use "lock tight" or add lock washers to the bolts I think should have it.
I straightened the front axle mount out.
#32 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 27, 2016 - 09:15 PM
Sorry for a delay, Flat car Tires, Busted water hose, Thunder Storms, Major upgrades at work, And other projects took all my time. Soon as I get freed up I'll get back to LJD.
  • KennyP and TexasG have said thanks
#33 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 29, 2016 - 08:10 AM
I was looking through the operator manual to see what type fluid the transaxle takes, SAE 30 seems to be correct. What concerns me is the references to "Do not change the oil, or damage WILL occur". I noted that there is a drain plug on this. Has anyone changed their transaxle fluid? As noted before, I can spin the pulley by hand and observe axle movement.
#34 Cat385B OFFLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted July 29, 2016 - 09:54 PM
I changed the transmission oil on the 185 I used to have, with no ill effects.
  • larrybl said thank you
#35 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 29, 2016 - 10:33 PM
What did you use? Oil wise. I am thinking of up-ending the transaxle and pouring the old oil in a clean bucket to see what it looks like.
#36 Cat385B OFFLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted July 30, 2016 - 02:46 AM
If I remember right, the 185 called for 10w-30. I think it was different than the 165-175 models.
#37 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 30, 2016 - 10:03 AM
I was planning on just up-ending it and pouring the oil through the fill tube into a container to see what it looks like. Then fill with 30W
#38 UncleWillie ONLINE
  • 16,100 Thanks
  • 8,906 posts
Posted July 30, 2016 - 06:03 PM
Hogan and Newkirk seem impressed
  • larrybl and KennyP have said thanks
#39 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 30, 2016 - 08:57 PM
I was wondering if someone would guess what was on TV.
#40 Cat385B OFFLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted July 30, 2016 - 10:41 PM
Not sure we need to guess? Unless someone has never seen the show, that is.
#41 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 30, 2016 - 10:53 PM
I showed that picture to a co-worker, he had no clue.
  • TexasG said thank you
#42 Cat385B OFFLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted July 30, 2016 - 11:26 PM
He knew nothing? Nussing?
#43 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted July 31, 2016 - 10:33 PM
Some more parts restored today. Some more to go, I think I found an issue with the brake safety switch. No matter how I press this it shows a constant short. I found a possible replacement in my parts box that should work. By the diagram the switch should be (Closed - brake on) and (OPEN brake off). The switch I have has either option, I'll use the correct two terminals and BOLTS to attach. (Why rivet a part in that can go bad)?
  • backwoods and UncleWillie have said thanks
#44 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted August 02, 2016 - 06:17 PM
A little side tracked this extended weekend. Relatives (Wife Side) visited from WV. The Roper was the favorite to ride. I was able to clean and paint the remaining Little John chassis parts after they left for Oklahoma to visit His relatives.
  • backwoods said thank you
#45 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted August 03, 2016 - 08:35 PM
Ok, I have decided to just add oil to the hydro. It specifies 30W SE, CC, or CD. I have 30W Non detergent API-SA, and Detergent CF-2, CF.
Where can I find 30W SE, CC, or CD?
