JD 165 Hydro "Little John"
302 replies to this topic
#151 Alc OFFLINE
  • 6,748 Thanks
  • 7,398 posts
Posted September 24, 2016 - 02:03 PM
Larry I've removed some seals like that by using a sharp punch or awl to poke a small hole then screw a sheet metal screw , and use vise grips on the head. You might need to do that in more then one location
  • larrybl, KennyP and ericjr16 have said thanks
#152 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 24, 2016 - 03:07 PM
I have done that before, but there is so little metal on the lip I am afraid of damaging the aluminum casting. Looking close at the tool it appears that it is forced inside the seal then used to pull the seal out. I may talk with the Dealer Monday and see if they do a tool rental.
#153 KennyP OFFLINE
  • 37,506 Thanks
  • 45,509 posts
Posted September 24, 2016 - 03:48 PM
Betcha I could get it out without damage! Seen lots of those type of situations! A small screwdriver will be your friend!
  • larrybl said thank you
#154 Alc OFFLINE
  • 6,748 Thanks
  • 7,398 posts
Posted September 24, 2016 - 04:35 PM
Larry that tool looks like a pipe nipple lol Maybe you could find a size that works , heck maybe even pvc pipe
#155 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 24, 2016 - 07:24 PM
After inspecting closely I think I can get it out with the tools I have. Guess the hydro fluid will be changed after all.
  • KennyP, shorty, backwoods and 1 other said thanks
#156 Alc OFFLINE
  • 6,748 Thanks
  • 7,398 posts
Posted September 24, 2016 - 08:14 PM
Its enjoying seeing a youngster working along with a grownup
  • larrybl and shorty have said thanks
#157 ericjr16 OFFLINE
ericjr16
  • 1,051 Thanks
  • 575 posts
Posted September 25, 2016 - 06:45 AM
Best thing is him learning early!
#158 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 25, 2016 - 09:23 AM
It's looking good can't wait to see it finished it should look new again by the time your done
Sent from my SM-S820L using Tapatalk
#159 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 25, 2016 - 09:37 AM
And the winning seal removal tool is......... Flat blade screwdriver. "Thanks Kenny!" Just stuck it between the rubber seal and shaft and gently pried it out. The brass bushings and small hammer to tap the new one in. Hopefully this fixes the leak.
  • backwoods and TexasG have said thanks
#160 Alc OFFLINE
  • 6,748 Thanks
  • 7,398 posts
Posted September 25, 2016 - 09:46 AM
Great to hear What's next ?
#161 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 25, 2016 - 10:01 AM
Not much today as it is pouring rain. I started on the fender pan yesterday and found a small crack, I talked with my neighbor and he will weld it for me, not sure when. I'll put the Hydro back together and run it again for a few minuets today and check the leak again. May clean and mask the hood decals in prep for light sanding.
#162 UncleWillie ONLINE
  • 15,530 Thanks
  • 8,710 posts
Posted September 25, 2016 - 12:25 PM
Good work on the seal.
#163 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 25, 2016 - 01:02 PM
Ran him for about 5 minuets at 10:00 this morning. Now 1:00 and still dry! :thumbs:
  • Cat385B said thank you
#164 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 25, 2016 - 03:37 PM
It's no monster GT, but I think you're going to be really happy with this. You've done a fantastic job. Arguably, the JD 165-185's, and their replacements, the LX172-LX188's, were some of the best LT's ever built. The transmissions were beefy for an LT, and the engines were excellent.
  • larrybl and TexasG have said thanks
#165 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,350 posts
Posted September 25, 2016 - 04:00 PM
Thanks Kat385B, My grandson was over this weekend. We spent some time talking about what was done while he was gone. Went over the leak issue, and what was still to be done. I told him Grandma decided on a new bed for him instead of new tires. If he had been here Grandma might have been out voted. Can't speak for the transaxle or deck yet, but When starting the engine it revs smooth and the governor response is tight. Kinda humid today, but with the shop doors open I was able to start on the hood. This paint has to dry 24 hours before I can do the other side.  Shrinking the picture makes it look funky, When I finish I'll post regular pictures.
Edited by larrybl, September 25, 2016 - 04:02 PM.
