For Sale
WHEEL HORSE FOR SALE
3 replies to this topic
#1 HANKG OFFLINE
HANKG
  • 5,595 Thanks
  • 3,087 posts
Posted May 02, 2016 - 05:53 PM
IMG_1406.JPG IMG_1412.JPG IMG_1409.JPG IMG_1407.JPG IMG_1408.JPG This is a 1966 1056 wheel horse, it is not mine but a friend asked if I would post it he's asking 400.00 I would offer him 300.00 it has a K241 I don't think the engine is the correct spec for the tractor since its footprint does not fit the frame bolted on one side only,IMG_1405.JPG easy fix with short piece of angle iron the carb will need to be cleaned he said it will run nice. Probably need battery also needs a little TLC  IT is however a tank.
Edited by HANKG, May 02, 2016 - 05:57 PM.
#2 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,184 Thanks
  • 8,521 posts
Posted May 02, 2016 - 07:53 PM
For $300, it should have a deck.
  • boyscout862 and HANKG have said thanks
#3 Racinbob OFFLINE
Racinbob
  • 74 Thanks
  • 66 posts
Posted May 03, 2016 - 10:40 AM
Don't worry about the right side motor mount tabs hanging over like that. It's normal. Look under the frame and you'll see two bolts that run into threaded holes in the oil pan. All the 'big block' (10-16) K-series hang over like that.
  • HANKG said thank you
#4 HANKG OFFLINE
HANKG
  • 5,595 Thanks
  • 3,087 posts
Posted May 03, 2016 - 02:25 PM
Thanks for the info, I was not aware of that, although I could not find the spec number listed in the red square forum for that tractor but they only list known numbers this one is 6333D. Thanks HANK.
