Briggs and Stratton 8B ignition problems
16 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 02, 2016 - 04:45 PM
I have a Briggs and Stratton 8B on an old Midland tiller that I am trying to get running, so far I have cleaned the flywheel magnets and so far no spark, I am not very familiar with these early aluminum block engines, so far this is number 2, (the other is a 6B-S that I have been able to figure out needs points and a condenser that I already have) what should I check first, the coil or the points/condenser?  Also, how do I remove the recoil ratchet on one of these as I have never seen one quite like this?
Type # is:9505056
Serial # is:5806100
Edited by adamjd200, May 02, 2016 - 04:46 PM.
#2 Bolens 1000 ONLINE
  • 14,220 Thanks
  • 17,846 posts
Posted May 02, 2016 - 05:20 PM
I would suspect the points and condenser to be the issue first rather than the coil, those seem to be good 7 times out of 10 on these engines.
Theres a tool for removing the clutches but if your careful a pipe wrench will loosen them up for you, (They are threaded on the crankshaft and act as the flywheel but)
  • Alc and Lauber1 have said thanks
#3 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 02, 2016 - 07:30 PM
I have one of the tools like this one:
Would this be what I need?
  • Bolens 1000, Alc, Lauber1 and 1 other said thanks
#4 BOLENSBUDDY OFFLINE
BOLENSBUDDY
  • 6 Thanks
  • 9 posts
Posted May 02, 2016 - 07:41 PM
yes
#5 Bolens 1000 ONLINE
  • 14,220 Thanks
  • 17,846 posts
Posted May 02, 2016 - 07:43 PM
Thats it :thumbs:
  • Lauber1 said thank you
#6 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 02, 2016 - 07:45 PM
Ok, for some reason I thought it was different, my bad.
#7 boyscout862 OFFLINE
  • 11,437 Thanks
  • 8,471 posts
Posted May 02, 2016 - 07:53 PM
Read the B&S Repairmans Manual for the older engines. It is very well written and is extremely helpfull. There are two of them in our Manuals Section. Good Luck, Rick
  • Alc, karel and adamjd200 have said thanks
#8 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 02, 2016 - 09:19 PM
I have one in book form, if this were a cast iron or later aluminum engine I wouldn't think twice, but I'm not too familiar with these early aluminum number series engines.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted May 02, 2016 - 10:20 PM
Its basically the same engine, just different metal.
  • Alc and adamjd200 have said thanks
#10 Tecumseh power OFFLINE
Tecumseh power
  • 1,420 Thanks
  • 1,082 posts
Posted May 03, 2016 - 08:50 AM
You can put a magnetron on it
#11 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 03, 2016 - 09:56 AM
Wouldn't be very easy, coil mounts completely different, plus I would have to find a donor engine, I think I'll just stick with points.
#12 Bolens 1000 ONLINE
  • 14,220 Thanks
  • 17,846 posts
Posted May 03, 2016 - 10:51 AM
Call me old fashioned but I always prefer points over electronic ignition any day :D
  • adamjd200 said thank you
#13 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 03, 2016 - 11:24 AM
I have never seen a magnetron coil that would bolt straight across to these old engines anyway, I suppose it could be done, I'm not gonna try.
#14 Bolens 1000 ONLINE
  • 14,220 Thanks
  • 17,846 posts
Posted May 03, 2016 - 11:29 AM
I figure if  they worked with points and condenser for 40+ years why change it?  :smilewink:
#15 adamjd200 OFFLINE
adamjd200
  • 1,883 Thanks
  • 2,011 posts
Posted May 03, 2016 - 11:33 AM
I tend to agree, I don't like to cut stuff up.
