Todays freebie! Need help
20 replies to this topic
#1 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 02, 2016 - 04:20 PM
Need help identifying this mtd model I got for free today. It is manual shift . And has a 10 hp cast iron briggs. And could any one help me maybe figure out the model number for the briggs ? Where the numbers are it's too rusty to read. Just need an idea incase I need parts. The mtd was painted and the tag is gone on it too
Edited by Tecumseh power, May 02, 2016 - 04:58 PM.
  • rustyoldjunk, boyscout862, Sawdust and 4 others have said thanks
#2 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted May 02, 2016 - 04:32 PM
Looks like an MTD 760. Great tractors! :thumbs: If you can strip off the paint from the engine shroud you should be able to read the numbers stamped into it.
Edited by MolonLabe, May 02, 2016 - 04:42 PM.
  • rustyoldjunk, boyscout862, holdenboy1960 and 1 other said thanks
#3 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,138 Thanks
  • 10,204 posts
Posted May 02, 2016 - 04:51 PM
What's a toadalso?
  • MolonLabe and Tecumseh power have said thanks
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 02, 2016 - 04:58 PM
Todays..sorry
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 02, 2016 - 06:02 PM
what is the difference between the 760.860.and 960?
#6 boyscout862 OFFLINE
  • 13,557 Thanks
  • 9,431 posts
Posted May 02, 2016 - 07:49 PM
The engine size. 760 is 10hp, my 860 is 12hp, and an 960 is 16hp. The manuals are in our library. They are a well built machine but the PTO lever is easy to accidently release with your right leg. Joe's had the parts that I needed to fix mine last summer. Good Luck, Rick
  • rustyoldjunk, holdenboy1960 and Tecumseh power have said thanks
#7 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 02, 2016 - 08:12 PM
thanks I already got it running, that wire on the points the branded one for ground needed soldered back onto the points plate. I found the manual. Thank you these are new to me. Don't seem like there is too many out there. Would that briggs be a model 23? It was nice of the guy to give it to me he saw all my suburban tractors and wanted it to go to a good home. He wouldn't take any money. I will find a deck for it. He had the pto and drive shaft for the deck
  • rustyoldjunk, boyscout862, Sawdust and 1 other said thanks
#8 jpswift1 OFFLINE
jpswift1
  • 793 Thanks
  • 616 posts
Posted May 02, 2016 - 11:05 PM
I like it!  Very nice tractor, and the price is right!
  • boyscout862, holdenboy1960 and Tecumseh power have said thanks
#9 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted May 03, 2016 - 12:28 AM
No the 10 hp is the next size up from the model 23. The 23 is 9 hp and the 10 hp is 24 c.i. The 23 is the last of the two digit model numbered engines. Your model number should start with 24xxxx.....Nice find by the way they are a hoss and use a Cub style clutch.
#10 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 03, 2016 - 06:16 AM
nice Machine the freer it is the better i think,  i can only dream of getting a MTD gt to go with my Riders to watch the crew grow
Shane
  • boyscout862 and Tecumseh power have said thanks
#11 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 03, 2016 - 08:48 AM
nice Machine the freer it is the better i think, i can only dream of getting a MTD gt to go with my Riders to watch the crew grow .
This guy lives in town by me. I work detail his cars and I fixed his leaf blower for him . I didn't know he had it. He just stopped one day and told me I have a tractor that I want to go to a good home . Come down and look at it. That's what it was. I tried to give him something for it . But he wouldn't take anything. I never saw an mtd in real life before
Shane
Edited by Tecumseh power, May 03, 2016 - 08:48 AM.
#12 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 03, 2016 - 09:37 AM
One more question? Is the peerless rear end that is in it a 2300? I need an axle seal
  • boyscout862 and holdenboy1960 have said thanks
#13 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted May 03, 2016 - 01:43 PM
The parts breakdown lists the transmission as a Peerless 2315-A which would use an MTD 78808 oil seal, same as my 960. Once you get the bugs out of it you are going to really appreciate what a capable machine it is. These dudes are heavy duty, you will love it.
#14 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted May 03, 2016 - 01:53 PM
Thanks MolonLabe, I ordered the seals the only other bug it has right now , is the bottom steering shaft bushing is shot . So the pinion slips when you turn the steering wheel. I looked at the parts listhat and got the bushing # when I search for it. Nothing comes up. So I will have to take the shaft and bushing out and measure the o.d and i.d and get one or make one.
  • boyscout862, Sawdust, MolonLabe and 1 other said thanks
#15 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 558 Thanks
  • 321 posts
Posted May 03, 2016 - 03:45 PM
Does the steering shaft have up and down play in it? I ask because mine did and required a 1/8" shim (washer) for the gears to mate properly.
  • boyscout862, VTXrider, Sawdust and 1 other said thanks
