Straw Bale Garden
15 replies to this topic
#1 jtrojek OFFLINE
jtrojek
  • 1233 Thanks
  • 616 posts
Posted May 02, 2016 - 11:01 AM
Has anyone here ever tried a straw bale vegetable garden before?  I was going to put in raised vegetable gardens for this year, but I did a little research into straw bale gardens and thought I'd give them a try.  There seems to be a number of advantages to them.  We'll see how it goes.  It doesn't sound like a well known idea, but it does sound like it may work well, definitely worth a shot anyway.  This weekend I laid the bales out, getting them ready.  It was nice that I could put them just about anywhere, thereby not using a bunch of real estate where the kids play.  I may move a few bales around yet to better spots as I'm not planting for a few weeks yet.  We'll see how this grand experiment goes, but I do have high hopes....
  • grnspot110, Alc, oldedeeres and 4 others have said thanks
#2 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted May 02, 2016 - 11:29 AM
I did one some years back..most productive easily maintained garden I ever had..potatoes come out perfectly round ..plant it somewhere out of the way though..clean up after the season can be a job.
  • Alc, boyscout862 and Sawdust have said thanks
#3 oldedeeres OFFLINE
oldedeeres
  • 15435 Thanks
  • 6818 posts
Posted May 02, 2016 - 11:35 AM
Lots of info on google about this, but most seem to utilize lots of added fertilizer. I have used a modified method called "Hugelkulture", but the results are not all in on it's efficiency. I'm hoping to get some raised beds going this year using straw and Hugelkulture theory in combination. Will be watching your posts to see how your project pans out, and I'll try to add my results when/if this project here gets going if you don't mind me tagging along.
  • Alc, KennyP, boyscout862 and 1 other said thanks
#4 easternharvest OFFLINE
easternharvest
  • 155 Thanks
  • 140 posts
Posted May 02, 2016 - 11:51 AM
That's funny, we decided to do a straw bale garden this year as well. The ground at our place is clay/shale and I didn't have time to get the ground prepared. So had to go to plan B. We are doing a combination of square foot garden using the straw bale method.
#5 MiCarl ONLINE
MiCarl
  • 2659 Thanks
  • 1321 posts
Posted May 02, 2016 - 11:53 AM
My wife did one a couple years ago.  The deer really appreciated they didn't have to reach down as far to feed, the rabbits not so much.
  • Alc, boyscout862 and oldedeeres have said thanks
#6 propane1 ONLINE
propane1
  • 13502 Thanks
  • 5956 posts
Posted May 02, 2016 - 01:44 PM
Never seen that before, would mice and other rodents be attacked to the straw ?
Noel.
  • boyscout862, Auburn David and CanadianHobbyFarmer have said thanks
#7 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted May 02, 2016 - 01:48 PM
Noel.
I never had a problem with them when I had mine.
  • boyscout862 and propane1 have said thanks
#8 boyscout862 OFFLINE
  • 15177 Thanks
  • 9995 posts
Posted May 02, 2016 - 02:56 PM
I can see where that would allow a garden to be put in earlier, in a cold climate. It looks expensive to me. The 8 bales of hay would be about $50 around here. Good Luck, Rick
  • propane1 said thank you
#9 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted May 02, 2016 - 05:10 PM
Noel.
I have mulched my garden with straw in the past and I did have issues with rodents. The first year it was really effective at keeping the weeds down though, so I tried it again. The second time around, the guy I got the straw from must have been having issues with his combine, because I ended up with a fine crop of wheat growing up between my rows of vegetables. I am still on the fence wether to do it again this year or not.
Jim
  • Alc, propane1 and Auburn David have said thanks
#10 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted May 02, 2016 - 05:42 PM
They work better the 2nd and 3rd year you use them..I didn't know that and I cleaned all mine up after the first use and a guy took them home and used them another 2 years..
  • boyscout862 and Sawdust have said thanks
#11 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted May 02, 2016 - 05:44 PM
Also if you can find hay that has gotten wet you can get it cheap or free.
  • boyscout862, Sawdust and propane1 have said thanks
#12 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted May 02, 2016 - 07:58 PM
  we're doing it this yr w/ our carrots. Cutting the slots to fill w/ dirt was a b!tch. Tried the sawzall, chain saw and finally used the edger on the Mantis to get a start and then my single bit axe to cut down into the bale. If I do it next yr I'll cut the slots when they're dry w/ the chain saw and stick 1x8's or 1x10's in the slots before I start cooking them, then pull them out and fill w/ dirt.
                                      Mike
  • Alc and Sawdust have said thanks
#13 Auburn David OFFLINE
Auburn David
  • 2756 Thanks
  • 1962 posts
Posted May 02, 2016 - 08:17 PM
                                      Mike
Yea I did it with my electric chainsaw..can be a pain on tight bales..also drill some holes in some PVC and shove it through them..hook a hose pipe to it for easy watering from the roots up.
  • Alc and ol' stonebreaker have said thanks
#14 jtrojek OFFLINE
jtrojek
  • 1233 Thanks
  • 616 posts
Posted July 10, 2016 - 05:06 PM
Straw bale garden is coming along. We have learned some lessons along the way, things that we'll do differently next year. No weeds, but a lot of mushrooms though. Anyway, we're happy with the results so far. Want to put in a drip line next year, among other changes.
  • DH1, grnspot110 and Sawdust have said thanks
#15 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted July 10, 2016 - 05:46 PM
Looking pretty good there sir, your idea works.  :thumbs:
