For Sale
Wesco Powered Stacker For Sale
wesco pcbfl-76-25 hydraulic power unit fork lift powered lift
3 replies to this topic
#1 DBTechServ OFFLINE
DBTechServ
  • 7 Thanks
  • 9 posts
Posted May 02, 2016 - 09:46 AM
I have a Wesco PCBFL-76-25 Series Counter-Balance Fork Model Powered Stacker for sale.
Max Lift Height = 76", Max Load = 1000 lbs with a 13" load center of gravity
The unit works great. Video of it in operation is available.
I picked it up for the 12vdc hydraulic power pack but, it works so well, I thought I would offer it for sale before I stripped it.
The unit has 300# of counter weights with it which you normally have to buy separately.
Does not come with battery or battery charger. It uses standard 12v battery, suggest deep cycle style for long term use.
Technical Specs as per Wesco site:
  • Item Counterweight Base Stacker
  • Load Capacity 1000 lb.
  • Lifting Height Max. 76"
  • Lifting Height Min. 1"
  • Fork Length 25"
  • Fork Width 3"
  • Base Legs Inside Dim. 38" to 50"
  • Base Legs Outside Dim. 21"
  • Overall Length 61"
  • Overall Width 27"
  • Overall Height 92"
  • Front Caster Dia. 4"
  • Rear Caster Dia. 5"
  • Front Wheel Dia. 5"
  • Rear Wheel Dia. 5"
Asking $1250.00 OBO
  • Traill95 and donoriscem have said thanks
#2 MH81 OFFLINE
Posted May 02, 2016 - 10:12 AM
I've seen these in use at appliance repair centers before with a platform on them
Get the unit on the lift and raise it to where you can work.
I'm sure it will make someone a handy garage addition, good luck.
  • DBTechServ said thank you
#3 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted May 02, 2016 - 10:24 AM
They also make a good fork lift attachment.I mounted a similar Presto on a Steiner.
  • MH81 and DBTechServ have said thanks
#4 DBTechServ OFFLINE
DBTechServ
  • 7 Thanks
  • 9 posts
Posted May 02, 2016 - 12:29 PM
I like the Steiner :thumbs:
MH81 - yeah I've seen them used as portable work positioning lifts/tables too. I just don't want to scrap it since it works perfectly.
  • MH81 and Username have said thanks
Also tagged with one or more of these keywords: for sale, wesco, pcbfl-76-25, hydraulic power unit, fork lift, powered lift
