new to simplicity
8 replies to this topic
#1 searssuburbanguy OFFLINE
searssuburbanguy
  • 1 Thanks
  • 7 posts
Posted May 01, 2016 - 09:55 PM
Hi I just bought a simplicity 3112h and I'm new to simplicity tractors and was wondering if anyone is familiar with this model who could answer my questions?
  • Dieselcubmike said thank you
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted May 01, 2016 - 10:06 PM
What questions do you have?
:welcometogttalk:
#3 searssuburbanguy OFFLINE
searssuburbanguy
  • 1 Thanks
  • 7 posts
Posted May 01, 2016 - 10:09 PM
It free wheels no matter where the neutral lever is positioned,is it supposed to do that or is something screwed up?
#4 oldedeeres ONLINE
oldedeeres
  • 10,512 Thanks
  • 5,106 posts
Posted May 01, 2016 - 10:28 PM
Welcome aboard  :wave:
  • searssuburbanguy said thank you
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted May 02, 2016 - 12:15 AM
Hello and welcome   :wave:
#6 Talntedmrgreen OFFLINE
  • 3,290 Thanks
  • 2,316 posts
Posted May 02, 2016 - 06:33 AM
Welcome!  If the freewheel lever is not affecting operation, it sounds like you have a problem, unfortunately.
Is your axle tube rotating, or not?  Here is a couple pics of the freewheel lever assembly.  It's rare, but the ball stem on the internal linkage can break, and you will need to open things up to fix it.
  • Gtractor, boyscout862 and HANKG have said thanks
#7 boyscout862 OFFLINE
  • 13,560 Thanks
  • 9,434 posts
Posted May 02, 2016 - 06:56 AM
Welcome to GTT. You can download some of the manuals for it in our Manuals Section. Good Luck, Rick
#8 John Arsenault OFFLINE
John Arsenault
  • 2,951 Thanks
  • 1,334 posts
Posted May 02, 2016 - 08:03 AM
Neutral Position? position on the  Hydro lever for the drive or the lever located in the back of the tractor?
It don't matter what you do with the drive lever, its the lever in the back of the tractor that put the tractor in and out of gear. That lever in the back is the only way to get your hydro to free wheel. The drive lever just opens and closes a port to limit fluid flow for speed adjustment.
#9 toppop52 OFFLINE
toppop52
  • 5,548 Thanks
  • 4,907 posts
Posted May 02, 2016 - 08:41 AM
Does it have a foot clutch like my 4041 PowrMax? If so, make sure it's engaging properly.
