Carb Swap
10 replies to this topic
#1 gearheadmike OFFLINE
gearheadmike
  • 12 Thanks
  • 16 posts
Posted May 01, 2016 - 02:36 PM
Ok so i got a sear suburban 12 hp Tecumseh and  the carb im having hard time finding kit and it looks a little corroded i just assume change it. Well i think is a off brand from factory no lme mark on it. Is there any other carb that will bolt on and run right. Im not to concerned about choke or throttle cable hook up as it will be getting a gas pedal.
#2 Bolens 1000 ONLINE
  • 15,409 Thanks
  • 18,278 posts
Posted May 01, 2016 - 02:47 PM
Do you have a picture of the carb you have?
  • Auburn David said thank you
#3 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,103 Thanks
  • 10,175 posts
Posted May 01, 2016 - 04:23 PM
A little corrosion isn't a big problem. If anyone can help you, Dr. Bolen can.
  • jpackard56 and WNYTractorTinkerer have said thanks
#4 TAHOE ONLINE
TAHOE
  • 8,298 Thanks
  • 5,800 posts
Posted May 02, 2016 - 07:15 AM
If you are dead set on changing it, look for a used LME or a carb from a Kohler 8-10 Hp will fit, but linkages will be different. I have a buddy who mounted one on his HH120 and he said it never ran that good, but they are getting difficult to find for a reasonable price.
Edited by TAHOE, May 02, 2016 - 07:20 AM.
#5 gearheadmike OFFLINE
gearheadmike
  • 12 Thanks
  • 16 posts
Posted May 02, 2016 - 12:38 PM
After looking at my carb closer i guess it is good enough for rebuild the choke/throttle shafts are still tight also the numbers are  6790023   with 38 on the other side.
#6 dodge trucker ONLINE
dodge trucker
  • 2,812 Thanks
  • 3,440 posts
Posted May 06, 2016 - 12:10 PM
Not a walbro just your garden variety Tecumseh carb.
#7 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,243 Thanks
  • 6,065 posts
Posted May 06, 2016 - 12:25 PM
I aleays google the number stamped on the carb..
Why mess with old one when you can just bolt on a replacement HERE
Edited by WNYTractorTinkerer, May 06, 2016 - 12:27 PM.
#8 gearheadmike OFFLINE
gearheadmike
  • 12 Thanks
  • 16 posts
Posted May 06, 2016 - 08:17 PM
  I see that carb has another spot for a hose?
#9 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,243 Thanks
  • 6,065 posts
Posted May 06, 2016 - 10:23 PM
It's the fuel inlet..  His is missing or is a part he removed.  As long as the bore & mount & jetting is the same it will work..
Edited by WNYTractorTinkerer, May 06, 2016 - 10:52 PM.
#10 EricFromPa ONLINE
EricFromPa
  • 4,162 Thanks
  • 3,345 posts
Posted May 07, 2016 - 08:39 AM
Don't think that's the original Walbro LME carb for a HH120.Looks like the one on my little H50 and H70.
HH120 12hp Carbs are Walbro LME 27, 33, 34 and 36 HH100 10hp Carbs are Walbro LME 16, 17, 25, 26, 28, 29 and 37
These 2 are HH100 carbs but they will work once you give them a good cleaning and put a carb kit in them.They are getting pretty hard to find in good condition.
This one will work.
http://www.ebay.com/...ssAAOSw3mpXK2of
This one will work
http://www.ebay.com/...vUAAOSwhRxXJ1ku
Edited by EricFromPa, May 07, 2016 - 08:41 AM.
  • TAHOE said thank you
#11 EricFromPa ONLINE
EricFromPa
  • 4,162 Thanks
  • 3,345 posts
Posted May 07, 2016 - 08:50 AM
That's for a 7-10hp snow blower.It might fit but it will run very lean.The Venturi in those are to small for a HH120.
