Allis Chalmers 616... Is it worth the price?
8 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted April 30, 2016 - 08:44 PM
On my local Craigslist is this AC 616... It has my curiousity. Is the hitch really CAT 0? The tires look all wrong... But what is a hydrologic leak??
https://parkersburg....5564468756.html
Yes I do see all the overspray...
Edited by MH81, May 01, 2016 - 06:59 AM.
#2 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 8,638 Thanks
  • 4,702 posts
Posted April 30, 2016 - 09:20 PM
Those front wheels would have to go.
  • wvbuzzmaster said thank you
#3 HowardsMF155 ONLINE
  • 2,774 Thanks
  • 2,949 posts
Posted April 30, 2016 - 09:30 PM
These tractors are found in the "Farm Tractor" section of TractorData.
http://www.tractorda...almers-616.html
#4 HowardsMF155 ONLINE
  • 2,774 Thanks
  • 2,949 posts
Posted April 30, 2016 - 09:33 PM
I notice TD states it uses an ONAN engine, but see a picture of a Kohler.
#5 glgrumpy OFFLINE
  • 8,362 Thanks
  • 7,747 posts
Posted April 30, 2016 - 09:47 PM
Nice larger chassis for a GT, like that.  Would think bigger twin should be in it also, not a single, but that is a good engine if running OK.  Not a great price, but seems worth looking at. Entire paint and fix-up would be on my list tho to be real neat.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,152 Thanks
  • 9,625 posts
Posted May 01, 2016 - 12:35 AM
As others pointed out, it's missing the original Onan. The right hand discharge white deck is for that tractor, the other is not. The only original rim is the right rear. The left rear is even a different size, bet that's doing wonders for the rear diff.
Rear 3 point is Cat 0.
A hydrologic leak is when you leave the fill cap off the fill neck, it gets water in it, and it freezes. Logic then states the hydro will leak. Hydrologic.
  • MH81, wvbuzzmaster and boyscout862 have said thanks
#7 EricFromPa ONLINE
EricFromPa
  • 3,224 Thanks
  • 2,908 posts
Posted May 01, 2016 - 01:04 AM
Logic states that he might be smoking something.
Tractordata might be a bit cheeky on the weight? 1,500lbs?  And they have a Bolens HT20 listed at 1,050lbs?
  • Bill 76 said thank you
#8 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted May 01, 2016 - 07:00 AM
That's with me sitting on it...
Whatever his sins in what he's done to this tractor, he has a nice Sears in the background of one pic.
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,152 Thanks
  • 9,625 posts
Posted May 01, 2016 - 08:01 AM
Which explains how he ended up with a Kohler in it, he's got a boneyard going on there.
The Kohler is going to be a bit underpowered vs. the original Onan twin under a load.
