What tiller fits?
10 replies to this topic
#1 Swrodgers OFFLINE
Swrodgers
  • 27 Thanks
  • 14 posts
Posted April 30, 2016 - 07:22 PM
Trying to find a tiller for my homelite
T-10. Still new to GTs but from what I've read simplicity's will fit, just not sure which ones or what to look for.
  • hamman said thank you
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,598 Thanks
  • 2,909 posts
Posted April 30, 2016 - 09:17 PM
Go to the simple tractors site. On there they will have a section where you can see what tillers by model number that will work on your Homelite. It will also tell you what other attachments you need. You will need a rear lift for your tractor. Some of the older Homelite rear lifts had a rectangle bar. The simplicity and Allis Chalmers have a round bar that fits the rear lift. My Homelite has a Simplicity tiller and I have to offset it about a 1/2 " to one side to make it fit. I can't get pics to upload or I would post some for you. Good luck .        Roger
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted May 01, 2016 - 12:52 AM
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted May 01, 2016 - 06:26 AM
Make sure you have or get the rest of the belt routing.
I remember a Simolicity guy saying that it's important to make sure you have the pullies for the same style as as your tiller.
Seems there were a couple of different styles.
#5 Swrodgers OFFLINE
Swrodgers
  • 27 Thanks
  • 14 posts
Posted May 01, 2016 - 09:15 AM
Thanks guys. Yeah I don't have any of the pulleys yet. Have located PTO pulley and idler arm assembly. Hopefully it fits.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted May 01, 2016 - 09:54 AM
An Allis-built Homelite tiller belt pulley:
  • MH81, hamman and Swrodgers have said thanks
#7 hamman ONLINE
hamman
  • 6,598 Thanks
  • 2,909 posts
Posted May 03, 2016 - 09:40 AM
I got a few of the pictures to load. Can't figure out why some will load and some will not. These are of the Simplicity tiller I got with the mule drive. I had to add the pulley to the tractor and the belt guides, which I made. Good luck.                                                  Roger
  • KennyP and Swrodgers have said thanks
#8 Swrodgers OFFLINE
Swrodgers
  • 27 Thanks
  • 14 posts
Posted May 04, 2016 - 12:18 AM
Perfect thanks for all the pictures fellas. Got a good idea what to look for now. Where would the belt guides be located. I know there will need to be one for the pulley comin off the tractor. Are there any more.
#9 hamman ONLINE
hamman
  • 6,598 Thanks
  • 2,909 posts
Posted May 04, 2016 - 09:54 AM
On the left side of the tractor under the seat there is the shaft for the pulley for the rear attachments. Just above and below there are holes for bolts for the belt guides. I made mine as they are not available anymore. Now that being said, I believe that you could look around at different tractor makes and see what they have for belt guides and make them work. I just happened to have some rod and a Oxy, aceteline torch to heat and bend the way I needed in a vise. Those are the onlt two i know of in this area.
This is the only one I can get to post right now. not the best but you can see where they are.
You have to have both of them and they need to be long enough to go past the belt by about a 1/2". They need to be within a 1/2" of the belt also. Good luck.
  • Swrodgers said thank you
#10 hamman ONLINE
hamman
  • 6,598 Thanks
  • 2,909 posts
Posted May 04, 2016 - 11:57 AM
Another picture of the belt top keeper and almost of the bottom keeper and the routing of the belt.
#11 Swrodgers OFFLINE
Swrodgers
  • 27 Thanks
  • 14 posts
Posted May 04, 2016 - 09:46 PM
Good deal. I can make somethin up to make it work. Thanks a lot hamman.
