1972 E12M
34 replies to this topic
#16 IamSherwood OFFLINE
  • 8,391 Thanks
Posted May 22, 2016 - 05:53 PM
How's this project coming along Doug?
#17 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted May 22, 2016 - 06:58 PM
I just got in from cutting some grass with it, works OK.
I took the mid mount rear discharge mower deck off of the EGT200, put it on the GE12M to try it out, some problems showed up but there fixable and that's what I'm working on.
I have a spare side discharge deck for the 12M, it's an Orange New Idea deck but the same as what would of come on the 12M.
This deck needs lots of work, everything seized, I have some spare mid mount motors and I'm hoping I can get it up and running soon.
The batteries that came with the 12M are good for about 1-1/2 hrs run time when cutting grass. New batteries would run 3hrs.
The fuel meter always reads low and the power use meter is always pegged max, the main disconnect switch is not so good, the charger is not working or the lights, and I'm trying to get new seat cushions for it but need to drill out 3 busted bolts from the metal pans that form the cushions.
The good news is that the motor and drive controls seem to be all working good.
So I'm pecking away at it as time allows, the new job I got is good, good people to work for.
  • Mr Electrak, wvbuzzmaster, IamSherwood and 4 others have said thanks
#18 IamSherwood OFFLINE
  • 8,391 Thanks
Posted May 22, 2016 - 07:09 PM
Good to hear you like the new job. :thumbs:
  • DH1 said thank you
#19 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted May 23, 2016 - 05:25 PM
Today  was cutting grass again maybe 3hrs total with a 1 hr recharge/lunch break.
I replaced the fuel meter with another one I had and it reads lower than the one that was in it. ???
The power use meter gets it's reading from the voltage loss on a piece of 20" wire from the main power disconnect, all the tractors power goes through this wire. Since my meter is always pegged when using the tractor I removed the wire, cut the 2 lug ends off, tried to cut off as little as possible, replaced them with new ones and reinstalled the wire. Now the power use meter is reading where it should, in the green, when going up hill while cutting grass it reads high green or just into the yellow zone. Starting the mower deck it goes into the red momentarily till it gets up to speed then drops into the low green zone. Works much better now.
Also I removed and disassembled the main disconnect switch, cleaned all the contacts, installed the missing main fuse link, safety fuse in case of a major short, and reinstalled it back in the tractor.
Found a intermittent bad connection on the fuse block, fixed that.
Replaced 1 front tire tube that wasn't holding air, the tires a cracked up pretty bad.
And I got a key switch with extra keys coming.
Tractor is slowly getting better and better, I like it.
  • Mr Electrak, KennyP, sacsr and 1 other said thanks
#20 KennyP ONLINE
  • 38,304 Thanks
  • 45,899 posts
Posted May 23, 2016 - 05:46 PM
Glad you are figuring it out!
#21 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted September 04, 2016 - 07:06 PM
UPDATE
Being using this tractor every now and then mainly to cut grass and haul a small trailer around.
I have had 2 different cutting decks on it, side discharge and rear discharge, both do the job, not sure which one I like better, they say side discharge is better for long heavy grass but I find the shoot plugs up quickly.
One thing I notice with this tractor is the power at the blades is not as strong as my other E15 tractor, just doesn't seem to cut the long heavy stuff as fast, the blades slow down more and sometimes the circuit breaker for one of the mower motors trips.
It has more now than when I first started cutting, I think there must be a bad connection in the PTO circuit or the PTO contactor itself not so good, something else to fix.
Anyway for now it's working and I'm enjoying using it. :dancingbanana:  :dancingbanana:  :dancingbanana:
  • KennyP, sacsr, CRFarnsworth and 1 other said thanks
#22 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted September 05, 2016 - 03:00 PM
Took the shoot off the side discharge deck today and it doesn't plug up at all now, cuts better, faster, but could throw a rock at someone.
Maybe a rubber flap might do the job. ???
  • KennyP, sacsr and CRFarnsworth have said thanks
#23 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted April 16, 2017 - 08:31 PM
About a week ago I put the lift and sleeve hitch on the 12M and tried some plowing with it. I was wondering if it could pull the plow with it's smaller motor, single drive belt, and 3sp trany, it did it, a little slow in 1st gear, power use meter in the high green to yellow, 2nd gear it's faster but the meter is in the red and the belt wants to slip, pushing it a little to hard I think. 1st gear is OK.
Now it's time to get the mower deck back on it for grass cutting duties.
  • sacsr and CRFarnsworth have said thanks
#24 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,142 posts
Posted April 16, 2017 - 09:14 PM
Which tractor are you bringing to "plow day"?
I would be very interested in how well you do.
I'll be checking out your hitch and plow set up.
I still have an E14 and would love to plow with it.
I haven't really looked for a hitch, I assume they can still be found.     Rick
#25 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted April 16, 2017 - 09:18 PM
If all goes well the E15 with Alltrax, best batteries I got, electric rear lift and Brinly 10" plow.
  • KennyP, CRFarnsworth and TomLGT195 have said thanks
#26 TomLGT195 OFFLINE
TomLGT195
  • 3,827 Thanks
  • 2,814 posts
Posted April 17, 2017 - 05:11 AM
Which plow day? Watson, Pa?
#27 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,142 posts
Posted April 17, 2017 - 07:32 AM
Sorry. I was asking about Ball Hollow Plow Day.
  • DH1 and TomLGT195 have said thanks
#28 Billy M OFFLINE
Billy M
  • 668 Thanks
  • 547 posts
Posted April 17, 2017 - 09:05 AM
Hey DH...don't forget the 12M has bushings in the axle tubes vs. bearings in all the other large frames.  I also had to replace a drive motor on a 12M that was used for a lot of blade/pushing duties.  The 12M is great for mowing.  They just don't hold up like the others with ground-engaging attachments.  Either way, nice looking setup.  Looks like it works well!
  • DH1, sacsr and CRFarnsworth have said thanks
#29 TomLGT195 OFFLINE
TomLGT195
  • 3,827 Thanks
  • 2,814 posts
Posted April 17, 2017 - 03:46 PM
So when is that one?
#30 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,567 posts
Posted April 17, 2017 - 03:48 PM
Here it is, happens on the same day as PA Plowday.   http://gardentractor...april-21st22nd/
  • TomLGT195 said thank you
