bills jim dandy pics
10 replies to this topic
#1 bill3t OFFLINE
bill3t
  • 52 Thanks
  • 91 posts
Posted April 30, 2016 - 09:03 AM
it has 48 inch mower. bill
  • daytime dave, Alc, IamSherwood and 5 others have said thanks
#2 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Lord that is beautiful!
  • bill3t said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 30, 2016 - 09:46 AM
One day maybe mine will look that good! Damn!
#4 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted April 30, 2016 - 11:16 AM
Very nice ! I have the older Jim Dandy with the C channel type frame
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted April 30, 2016 - 11:26 AM
wow.  that is great!  u did a fine job with that one!   just like new
#6 MNGB OFFLINE
MNGB
  • 2,114 Thanks
  • 1,405 posts
Posted April 30, 2016 - 12:44 PM
You done good that is a nice looking JD will give you years of service now.
#7 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 30, 2016 - 12:48 PM
That's a dandy looking dandy!!!! Would love to find one around here I could afford.
Pete
#8 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,913 posts
Posted April 30, 2016 - 03:56 PM
Nice work, looks nice!  Wondering about that mower mount??  Zat really the PK brand or nice home-built?  Seems deck needs to raise in front as you noted on other post, but sure don't know how.  If that is PK mount, it is new one to me, have no idea.  I would have to look thru the thumb-drive to find that one if stock. Even the mule drive is quite diff from standard PK?  I see the mount blocks for modern blade and such,  just not familier with that mower mounting. Rear rollers look right, the chain lift. Front part, not sure of.
#9 bill3t OFFLINE
bill3t
  • 52 Thanks
  • 91 posts
Posted April 30, 2016 - 05:27 PM
I did a two hundred mile road trip to find the mower deck and drive. i havnt raised the front of deck yet. going to drill some holes in drive up higher. i think it will work. i believe the drive is a real pk. bill
#10 icpik OFFLINE
icpik
  • 23 Thanks
  • 40 posts
Posted May 02, 2016 - 03:27 PM
In the second picture, can you remove the quick release pin at the back end of the connection bar and reconnect through the lower hole?  Might raise it half an inch.
Don Hayes
#11 bill3t OFFLINE
bill3t
  • 52 Thanks
  • 91 posts
Posted May 03, 2016 - 06:49 PM
i removed the driver. drilled some new holes. raised up the deck 1 inch in the front. cleaned up moving parts and lubed with greese. should work good now.bill
