Carb Help Kohler Command CH20
kohler ch20
5 replies to this topic
#1 R Miller OFFLINE
R Miller
  • 4 Thanks
  • 16 posts
Posted April 29, 2016 - 10:53 AM
Hi. I'm having a problem with carb linkage. I removed throttle linkage and governor linkage now I'm putting back together. I know where the heavy spring connects from governor to throttle linkage. But there is another small spring that make no sense to me. or where it came from. Could someone please help me ? Or a photo. Thanks
#2 Bolens 1000 ONLINE
  • 15,433 Thanks
  • 18,286 posts
Posted April 29, 2016 - 10:58 AM
Hope this helps:
https://partstream.a...ne-parts-lookup
#3 sharkman OFFLINE
sharkman
  • 403 Thanks
  • 321 posts
Posted April 29, 2016 - 01:27 PM
How about this!
#4 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted April 29, 2016 - 02:02 PM
Yep, these new engines have lots of linkages and controls these days AND limited ability to adjust idles and throws of them. I'm getting into these on my Power Kings now. Even hard to figure out how to remove the stuff with right twist and turns. I didn't take picture either, might be in same boat with ya! I want one of those bender tools for setting idle by bending the rod with offset in it. Just some pliers and other tools, doesn't seem to be able to do it nicely.  New stuff takes "Special tools" these days.
#5 R Miller OFFLINE
R Miller
  • 4 Thanks
  • 16 posts
Posted April 29, 2016 - 07:31 PM
Thanks for replies. Thanks Sharkman for photo. Looks just like mine. I see large spring on governor... but do you have another smaller spring that I dont see ? Thanks.
#6 sharkman OFFLINE
sharkman
  • 403 Thanks
  • 321 posts
Posted May 03, 2016 - 01:34 PM
If you down load my picture and blow it up you will see a long small spring on the linkage from one side of the governor arm to the carb throttle (below the choke) and the larger spring on the other side of the governor arm to the bunch in the middle of the engine that your cables hooks into
Also tagged with one or more of these keywords: kohler ch20
