throttle and governor linkage question
2 replies to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted April 29, 2016 - 07:18 AM
On  Briggs and Stratton engines , and probably other makes, that I have worked on for years, often there will be a linkage rod (heavy wire), that runs through a very small spring. In cases like the 4 HP horizontal B & S that I'm working on now the link wire and the spring both hook in the same holes at each end. I wonder , since the link is a solid piece of wire, what is the purpose of the spring? Thanks.
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted April 29, 2016 - 07:24 AM
All that spring does is eliminate any looseness in the linkage.
  • Bolens 1000, DougT, boyscout862 and 4 others have said thanks
#3 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,920 posts
Posted April 29, 2016 - 02:14 PM
I've always wondered that too.  Seems that spring on one end is always worn thru on older ones and not doing much.
