BREADY TRACTOR NAMES
24 replies to this topic
#1 HANKG ONLINE
HANKG
  • 5,979 Thanks
  • 3,290 posts
Posted April 28, 2016 - 07:47 PM
The unusual Bready tractor group is amazing to me, established 1919 in Solon Ohio building walk behinds then later four wheel tractors powered by Briggs, Tecumseh and Wisconsin in variety of horsepower's. After purchasing a Bready "600" I started to do some research on them, what I found was they made tractors for Homelite Yeah,  Gilson yeah,IMG_1394.JPG  IMG_1395.JPG IMG_1399.JPG IMG_1402.JPG IMG_1400.JPG IMG_1398.JPG  Reo who? and Engray? what who knew, they are without doubt a rugged machine its no wonder the other big company's didn't mind badging their respective names on them.  All used the Crosley car T92 transmission I hijacked some photo's from another site I belong to  for those who may not have seen any before. The pics may not be the best .
  • rustyoldjunk, MH81, Alc and 11 others have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,192 Thanks
  • 5,790 posts
Posted April 29, 2016 - 08:35 AM
I want that green Bready!
  • HANKG said thank you
#3 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted April 29, 2016 - 01:22 PM
Thanks for the lesson.
I've seen a couple of those on here somewhere, I think
#4 Mtypython ONLINE
Mtypython
  • 329 Thanks
  • 334 posts
Posted May 01, 2016 - 05:59 PM
Didnt know about the last 2 names, hows your comming along, mines still sitting in the barn
#5 HANKG ONLINE
HANKG
  • 5,979 Thanks
  • 3,290 posts
Posted May 02, 2016 - 09:20 PM
Hi Mark, the Bready  project is just starting to get going, the original Briggs143302 6hp engine turned out to be junk it smoked . It also came with a Briggs 190402 8hp which was already on the tractor, after replacing the coil condenser it fired up and does not smoke. I want to keep it as original as possible and found another Briggs 6hp that is a cast iron block instead of the Alu. 143302 and this engine had been set to run on propane so it was very clean inside then switched over the parts from the original engine flo jet carb and air vane governor set up  this engine runs very well I took a shot on it for a 100.00 dollars and got lucky. Then I noticed the transmission was not spinning in neutral it was stuck so I pulled the cover off and there was no gear oil in it, but no water either so I bought a couple cans of PB blaster and shot it up real good on Saturday, and this morning I was able to get it spinning again and now shifts in all gears that stuff is amazing. So that's where that's at for now, I'm really getting busy with the Porter Cable restoration and hope to have it complete by the end of May. Thanks Hank
  • Alc, Bruce Dorsi and Mtypython have said thanks
#6 Mtypython ONLINE
Mtypython
  • 329 Thanks
  • 334 posts
Posted May 03, 2016 - 04:12 AM
Awesome hank, got my porter running had to clean carb, just going to leave it weathered as it is, need to get a set of front wheel bearings for it and a brake band for the mechanics.
#7 Alc ONLINE
  • 6,431 Thanks
  • 7,236 posts
Posted May 03, 2016 - 05:16 AM
Glad to hear it was a easy ( meaning cheap ) fix to get the trans free . :thumbs:
#8 HANKG ONLINE
HANKG
  • 5,979 Thanks
  • 3,290 posts
Posted May 03, 2016 - 06:31 AM
Yeah Al, I was sweating that one but had good info from member CLASSIC and any help I may need, the man knows his stuff.
  • classic said thank you
#9 tsmith1499 OFFLINE
tsmith1499
  • 20 Thanks
  • 10 posts
Posted February 23, 2017 - 10:31 PM
I have a homelite with eng. model # 143307. I was wondering if anyone can tell me what year it is?
#10 classic ONLINE
classic
  • 4,832 Thanks
  • 2,128 posts
Posted February 24, 2017 - 07:39 AM
tsmith, the serial number on your engine can be looked up to tell you what year the engine was built.
#11 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,863 Thanks
  • 2,429 posts
Posted February 24, 2017 - 08:05 AM
Hank:
What model is the cast-iron B&S
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,239 Thanks
  • 9,178 posts
Posted February 24, 2017 - 08:33 AM
It's interesting to me how many of these tractors, including the PK, Economy, et al, were built basically the same as the original homebuilts made from plans featured in magazines of a certain era. Was there really that much variation to warrant a patent?
#13 tsmith1499 OFFLINE
tsmith1499
  • 20 Thanks
  • 10 posts
Posted February 24, 2017 - 01:22 PM
I tried looking on the B&S website and only got more confused.  I found the number range listed but not the year. I looked in the pre 1965 section.  Believe it or not the actual tractor that I just bought is the first one in Hanks pictures.
Edited by tsmith1499, February 24, 2017 - 01:24 PM.
  • KennyP and HANKG have said thanks
#14 KennyP ONLINE
  • 35,089 Thanks
  • 44,105 posts
Posted February 24, 2017 - 06:06 PM
Post all the engine #'s, bet someone here can decode it!
#15 tsmith1499 OFFLINE
tsmith1499
  • 20 Thanks
  • 10 posts
Posted February 24, 2017 - 08:49 PM
model - 143307, type no. 502693, serial no. 189131
