Jake 1200 battery install ?
7 replies to this topic
#1 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 28, 2016 - 03:05 AM
Got a 1200 yesterday to repair, how does the battery box lid go on and what else is missing? I have the cover with shifting pattern on it , but that's it ! Does the battery sit on the frame or a block of wood ?? Does it have some spacer/ clampy thing on top to keep the he cover from shorting ?? I have no clue what I need to make or find?
#2 KennyP ONLINE
  • 40,939 Thanks
  • 47,126 posts
Posted April 28, 2016 - 05:00 AM
There is supposed to be a block of wood on top between the cover & battery. May see something in this manual. May find some help here also.
  • skyrydr2 and boyscout862 have said thanks
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 28, 2016 - 07:12 AM
I knew I could count on you coming through buddy, thanks, that was just what I needed. Customer wants it all fixed up so it will be dependable, it's almost complete too, only a few things that I noticed so far, one thing it will need is the seat pan rebuilt it's all gone inside and got tweeked some how during its life, also tires are rubbing in rear. Just need to swap as offset is not quite right.
#4 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,598 Thanks
  • 2,909 posts
I posted what I did to our 1200 super chief but I can't find the right thread. I'm still having trouble loading pics or I would post them. I had some drawings with measurements for the box cover as well as the top and bottom wood pieces. Good luck hope you can get it made.        Roger
  • KennyP and skyrydr2 have said thanks
#5 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 29, 2016 - 04:09 AM
I'll do up a nice custom cut wood piece for the battery hold down/cover insulator , biggest issue at the moment is going to be rebuilding the rot in the fender pan, the rest will be easy.
#6 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted April 30, 2016 - 02:12 PM
here is my repop battery covers with all the wood and hardware.
Edited by josh deaven, April 30, 2016 - 02:12 PM.
#7 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 01, 2016 - 11:29 AM
Thanks Josh, that is just what i will do for the one i have.
Got the rig running the other day, old buzzard purrs like a kitten.
I will say that i am not impressed with this generatiion of rig, the engine is a monster to service the points and generator on...
  • Rock farmer said thank you
#8 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 02, 2016 - 04:29 AM
Well, they got it all fixed up yesterday, the old rig runs and drives like a champ! The next thing they will want is the tiller hooked up, I'm sure. I'll snap a few pics of it, if I can remember, been crazy busy with plants, and green houses,farm stand, now it's time to start putting things in the ground, and next it will be hay.... I don't usually do the hay....
