SEARS SS16 TWIN mower deck problem
12 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 27, 2016 - 06:10 PM
I tried to  put the deck on my tractor today. I hooked it all up and the height adjuster lever don't work. there is a link right behind the right rear pin that attaches to the tractor that has a bolt on one end. and a slot that goes over a pin.does anyone have a pic of the correct setup when it is on a tractor? Im baffled. I picked the deck up with a forklift, forks were under where it attaches to tractor, so deck hung down, then the lever worked.
Edited by Xrperry, April 27, 2016 - 06:37 PM.
#2 dthomp17 ONLINE
dthomp17
  • 501 Thanks
  • 415 posts
Posted April 27, 2016 - 09:23 PM
I have a Sears SS16 twin and I believe two different mower decks will work on that tractor.  My mower deck has a scissor type lift on each side of the deck as shown in the picture. Is this any help?
  • Xrperry said thank you
#3 MH81 ONLINE
  • 27,984 Thanks
  • 28,941 posts
Posted April 27, 2016 - 09:33 PM
I have a ST16 at the farm with a deck. I can take pics if it'll help.
One thing, I remember that some of the rear hangers have two sets of holes. It may make a difference which hole it's in when bolted to the tractor.
#4 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 08:17 AM
Thanks for pics. first off deck # 917.253250. tractor # 917.25751. is this the right deck? seems the sissors are too long.will have pics later
Edited by Xrperry, April 28, 2016 - 10:03 AM.
#5 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 09:03 AM
after work today i will take some good pics of my deck and then everybody can check it out, maybe spot a problem.
#6 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 12:13 PM
i looked up the deck number and tractor number. tractor is suppose to be a 1973. the 1973 deck number is 917.253240. the deck i have is a 917.253250. anybody know the difference
#7 MNGB ONLINE
MNGB
  • 1,083 Thanks
  • 874 posts
Posted April 28, 2016 - 12:59 PM
I don't think there's any real difference in the deck mounting from 70 on up to late 70's I interchange my decks around all the time which ever ones handy I install it on what ever tractor I want a deck on generally put the 48" one on the SS16 but have had it on both of the ST16's. I not sure I understand what your saying some pictures may help clear things up. There are 4 spring loaded pins that attach the deck to the tractor no bolts the back tractor mounts a slotted and the front mts just have a hole for the pin, I get the deck under the tractor and use the lift lever to raise and lower the scissor levers to align the rear pins the then have to raise the front of the deck a bit to get the front pins in and locked. Here's a manual for the 48" deck the 42" is the same. If your deck looks like this it will fit
Attached File  917.253582 42 inch 917.253592 48 inch deck.pdf   9.63MB   28 downloads
Edited by MNGB, April 28, 2016 - 01:04 PM.
  • dthomp17 and Xrperry have said thanks
#8 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 01:21 PM
thanks mngb, it looks pretty much the same, the deck hooks up to tractor fine, i will have pics tonite.
#9 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 02:48 PM
ok here they are. pics are with handle forward, and back. handle seems to cam over on the link with the slot, no lift at all
#10 MNGB ONLINE
MNGB
  • 1,083 Thanks
  • 874 posts
Posted April 28, 2016 - 05:53 PM
I'm not sure whats going on but the slotted strap is suppose to remain vertical its not suppose to pivot at the attach bolt should remain as it is in the 3rd photo. Ok went into town and looked at one of the decks and took a couple of pictures when the lift lever is all the way back, the deck up position the arm on the pivot rod that is attached to the slotted part needs to be flat back on the deck and the slotted arm will be slightly aft of vertical when the lift lever is all the way forward / deck down  the arm on the pivot rod will be up towards vertical and the slotted arm just about vertical just slightly forward.HPIM2470.JPG HPIM2471.JPG
Edited by MNGB, April 28, 2016 - 06:51 PM.
#11 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 06:20 PM
IMG_0522.JPG Boy i dont know, it is bolted with a bushing. It does work when the handle is on wrong
#12 MNGB ONLINE
MNGB
  • 1,083 Thanks
  • 874 posts
Posted April 28, 2016 - 06:55 PM
Yes for some reason the arm on the pivot rod is not right  look at the pics I just attached and see if you see something. Look to see if the weld on the pivot rod broke and was re-welded wrong.
Edited by MNGB, April 28, 2016 - 06:57 PM.
#13 Xrperry ONLINE
Xrperry
  • 363 Thanks
  • 380 posts
Posted April 28, 2016 - 07:34 PM
Thanks for taking the time to do that for me mmgb. I thought the same thing about broken welds, didnt see any or re welded .i will compare your pics with the deck,.i could use it with the handle on wrong but it would irritate me worse than my underware stuffed with steel wool. I still have time before i need to mow , not going to give up.
