Understanding tire dimensions
17 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,308 Thanks
  • 1,269 posts
Posted April 27, 2016 - 11:05 AM
So me like most others who are fairly new to the hobby, don't quite understand tire dimemsions...
Can someone help explain?
What's the difference between 23x10.50-12 and 23x8.50-12 tires? Width? Sidewall height? Overall diameter?
Maybe this could be a sticky so that it is easily found by visitors to the site?
Thanks
  • hamman, IamSherwood, boyscout862 and 1 other said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,195 Thanks
  • 5,795 posts
Posted April 27, 2016 - 11:07 AM
The 10.50 is 101/2 inches wide. the 8.50 is 81/2 inches wide
  • limebuzz, hamman, boyscout862 and 1 other said thanks
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,195 Thanks
  • 5,795 posts
Posted April 27, 2016 - 11:08 AM
23 is overall height of the tire and 12 is the rim size
  • hamman, boyscout862 and Greasy6020 have said thanks
#4 petrj6 OFFLINE
petrj6
  • 4,081 Thanks
  • 2,369 posts
For garden tractor tires the first number is the overall diameter, second number is the width and the last is the rim size.
  • MH81, hamman, boyscout862 and 2 others have said thanks
#5 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted April 27, 2016 - 11:11 AM
23 = Tire Diameter = 23"
8.5 = Width = 8.5"
10.50 = Width = 10.5"
12 = Rim Diameter = 12"
I find that the cheaper Import tires really scrimp on these dimensions.  Some not even close.
  • TheFarm2004, limebuzz, hamman and 5 others have said thanks
#6 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted April 27, 2016 - 11:28 AM
A Deestone in  23x10.50x12 really means
22x9x12
  • ducky, TheFarm2004, limebuzz and 6 others have said thanks
#7 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,757 Thanks
  • 4,301 posts
Posted April 27, 2016 - 12:12 PM
I bought two Identical Hi-Run's 23 X 10.50 X 12 from TSC, and after mounting them, 12 psi each, there is a noticeable difference in the width between the two.
Edited by larrybl, April 27, 2016 - 12:12 PM.
  • TheFarm2004, limebuzz, hamman and 3 others have said thanks
#8 Greasy6020 OFFLINE
Greasy6020
  • 1,308 Thanks
  • 1,269 posts
Posted April 27, 2016 - 12:37 PM
Awesome thanks guys!
Edited by Greasy6020, April 27, 2016 - 12:37 PM.
#9 propane1 OFFLINE
propane1
  • 8,213 Thanks
  • 3,959 posts
Posted April 27, 2016 - 02:29 PM
Just like clothes, all say same size, but sizes are different between manufactures. And 6 x 12 tire means , six inches wide and twelve inch wheel. No mention of tire height on that type of tire.
Noel
  • limebuzz, hamman, Lauber1 and 1 other said thanks
#10 KC9KAS OFFLINE
KC9KAS
  • 5,267 Thanks
  • 4,643 posts
Posted April 27, 2016 - 06:25 PM
I would take both tires/wheels to them and ask them to replace one or he other so at least you had a matching set!
  • larrybl, ducky, limebuzz and 4 others have said thanks
#11 IamSherwood OFFLINE
  • 8,390 Thanks
Posted April 27, 2016 - 06:49 PM
Thanks
This is a really good thread. There is a bit of a grey area here, and standards don't exist
from one manufacture to another. (at least on the imports)
8.5 = Width = 8.5"
Yep, that's the way I see it too.
  • MH81 and Greasy6020 have said thanks
#12 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,757 Thanks
  • 4,301 posts
Posted April 27, 2016 - 07:01 PM
I adjusted them with Air pressure, 10 in one 15 in the other. More for show than work.
  • Greasy6020 said thank you
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted April 27, 2016 - 08:19 PM
Noel
and the real kick on those tires is they can be any where from 22" - 24" tall, depending on the age and maker of the tire.
  • MH81 and propane1 have said thanks
#14 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted April 27, 2016 - 10:41 PM
22x9x12
Glad I am not the only one that has had that happen.
Deestone is off my list of tire suppliers.
  • TAHOE said thank you
#15 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 9,962 Thanks
  • 5,580 posts
Posted April 27, 2016 - 10:43 PM
Usually the air pressure for rears is 8# ..  Those tires are blown up like balloons!
The different size issue is solved by always replacing them in pairs IMO..
  • larrybl said thank you
