New to GT's
9 replies to this topic
#1 Skemcis OFFLINE
Skemcis
  • 1 Thanks
  • 2 posts
Posted April 26, 2016 - 10:52 PM
Greetings Folks. Well, I am now the owner of a  Sears LT11 Lawn Tractor? Having always been a push mower type, I never thought I'd wind up with something like this. My son picked it up today then dropped it in my yard. No battery, a blown fuse, two flat front tires (with new spare tires), a very dirty 11h.p. B&S, and rust all over.
A quick search showed this beast isa 1981 model with no manual available from Sears. I don't mind monkey wrenching, but I really need to understand what I'm looking at, and if needed get the proper replacement parts if available.
This is a Model# 502.601140
Date of Manufacture ; 1133
The above on the metal plate attached to the back of the tractor.
My question; Is there a manual out there that can help me?
Any help would be greatly appreciated!
Ian
  • Traill95 said thank you
#2 James Bosma OFFLINE
James Bosma
  • 564 Thanks
  • 285 posts
Posted April 27, 2016 - 05:04 AM
Welcome to GTtalk  lots of great info and great guys and gals here to help
Did you check the manual section for your manuals
Your allowed to download 3 manuals a day
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,591 Thanks
  • 4,102 posts
Posted April 27, 2016 - 05:23 AM
:welcometogttalk:    if you're looking for this Unbenannt.JPG take this   Attached File  L0807078(1).pdf   1.64MB   54 downloads
  • Gtractor, MH81 and Alc have said thanks
#4 boyscout862 ONLINE
  • 10,947 Thanks
  • 8,203 posts
Posted April 27, 2016 - 06:02 AM
Welcome to GTT. The critical manual will be the Briggs and Stratton Repairmans' Manual because you need it for the engine. Once you get the engine running, then the other things should be easy to figure out. Good Luck, Rick
#5 MH81 ONLINE
  • 29,220 Thanks
  • 29,417 posts
Posted April 27, 2016 - 06:52 AM
:welcometogttalk:
Nice you are going to get wheels under you.
Looks like the guys have you covered on the manual, the B&S manual in our manuals section is a good knowledge base too.
You'll have to work thru wiring issues as I'm sure that a least one safety switch is temperamental.
Good luck, take and share pics, and ask questions as you need to.
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,591 Thanks
  • 4,102 posts
Posted April 27, 2016 - 07:00 AM
Probs with the engine? Have you tried to find an answer here at the B&S Support?
#7 Skemcis OFFLINE
Skemcis
  • 1 Thanks
  • 2 posts
Posted April 27, 2016 - 08:24 AM
Thanks for the pointers folks. Looks like I'm going to have a another project on my hands. That will make the wife happy.....chuckles!
#8 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,174 Thanks
  • 5,772 posts
Posted April 27, 2016 - 08:31 AM
:welcometogttalk: :camera:
#9 Oldford OFFLINE
Oldford
  • 906 Thanks
  • 639 posts
Posted April 27, 2016 - 01:24 PM
According to this chart it was made by murray http://vintagemachin...ufacturers.aspx
that might help you find parts if you need a donor machine.
small older ones like that are pretty easy to figure out if it's going to run/drive/cut, before spending too much time or money, good luck
#10 oldedeeres ONLINE
oldedeeres
  • 7,218 Thanks
  • 3,736 posts
Posted April 27, 2016 - 01:52 PM
Welcome aboard!
