No Foreward or Reverse
4 replies to this topic
#1 PoorOtis OFFLINE
PoorOtis
  • 1 posts
Posted April 26, 2016 - 06:52 PM
have a cub cadet LTX 1046..starts right up..PTO enguages and blades spin..but ...No Foreward/Reverse!
Its a 2011/50 year ann. model/hydrostatic. Any info will me helpful.Thank You
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted April 26, 2016 - 07:29 PM
Welcome to the forum. Check the manuals section for your tractor. I'm not experienced with them. A couple of generic hydrostat problems are that there is usually something to allow a hydrostat to be pushed by hand. If it pushes easy, look into how it works on your tractor. There is usually a foot pedal that releases the hydro that nobody uses and it gets pushed and sticks. Check fluids? Pump Drive?? How did the problem come about ? Any history on the problem or did you buy it this way? Hope somebody that knows something comes along and helps.
  • Gtractor and boyscout862 have said thanks
#3 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted April 26, 2016 - 10:25 PM
Welcome to GTT.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 27, 2016 - 05:14 AM
Welcome to GTTalk. . Most hydrostatic tractors have some sort of bypass valve that you activate so that you can push the tractor. If it's easy to push then that is a clue that something is disconnected mechanically or it is bypassed. If that isn't the problem I would also check the linkage from the travel speed control to the transmission and the drive to the transmission as well as the axle shaft keys which can shear off resulting in no drive.
#5 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,205 Thanks
  • 5,805 posts
Posted April 27, 2016 - 07:37 AM
:welcometogttalk: :camera: Throw a belt?
