John Deere 140
105 replies to this topic
#61 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted May 01, 2016 - 05:14 AM
Yes and yes.
  • JC 616 said thank you
#62 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted May 01, 2016 - 07:41 AM
Can a 3 point hitch be added to the H1? Also if I found the whole H3 setup can I just swap it out and convert mine to the H3?
Yes on the h-3 but there ARE different versions of the H-3 set-up based on the pump that was used.  You need a H-3 setup from a tractor that is serial number 30,001 and up.  This is what I used to convert my 120 to H-3.
#63 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 01, 2016 - 04:10 PM
Well good. Now I know what I'm looking for. Those 3 point hitches ain't cheap. Wonder how hard it would be to build your own
#64 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 01, 2016 - 04:15 PM
Got the weights off and the trac vac and the brush guard. Need to get a new ignition switch since it didn't come with a keyIMG_20160501_092327_535.jpg
#65 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted May 01, 2016 - 04:55 PM
Just get a key from someone as it is a standard (indak) design IIRC
#66 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 01, 2016 - 05:48 PM
So I just need the key only? Good info
#67 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted May 01, 2016 - 10:18 PM
#68 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 02, 2016 - 01:00 PM
Tried my key from my AC 616Hydro and it fits. Thanks Trav
#69 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted May 02, 2016 - 04:28 PM
:thumbs:  :thumbs:  :thumbs:  :thumbs:  :thumbs:  :thumbs:
#70 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 08, 2016 - 08:00 PM
Well tore it apart a little today. Got all the engine sheet metal off and got the head off.IMG_20160508_101350_908.jpg
Pretty nasty. Probably best to go ahead and have it machined. How do you get the sheet metal off from around the fly wheel. Anything I should do upgrade wise to the carb when I rebuild it. I just want this thing to run really really good when I'm done and mow with it.
#71 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 13, 2016 - 04:37 PM
Can't wait to get her completely stripped and cleaned up and some fresh paint. Wanna rebuild the steering. Its pretty sloppy behind the dash
#72 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 13, 2016 - 04:38 PM
I wanna pull the rear end and hydro out degrease it but not sure what to use on it to clean all the grime off of it
#73 Kollyn OFFLINE
Kollyn
  • 4 Thanks
  • 3 posts
Posted May 14, 2016 - 10:57 AM
I would use a degreaser and a scraper/screwdriver to get all the dirt and grime off. Also, maybe you could use a powerwasher?
#74 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted May 14, 2016 - 06:15 PM
With a big enough cylinder bore it will split just about anything but the cycle time would be in minutes and not seconds.
#75 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 14, 2016 - 06:25 PM
Yeah I thought about loading it up and taking some degreaser and taking it to the car wash and pressure wash it there.
