John Deere 140
105 replies to this topic
#46 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 06:17 AM
I use my tractors for yard work including mowing the lawn.  The parts from Kirk have make both of them much easier to start.  Well worth the money in my book.
#47 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 28, 2016 - 07:42 AM
Ok sounds good. So with the 10 over rebuild kit do I need to have machine work done?
  • Trav1s said thank you
#48 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 07:59 AM
Yes... but make sure the .010 kit will do it.  A machine shop will be able to verify how far it needs to be opened up then order a kit.  I have an extra .010 kit that I did not need.
#49 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 28, 2016 - 08:32 AM
What all is in the kit you have?
#50 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 09:28 AM
Full kit- piston/rings, rod, gaskets
#51 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 28, 2016 - 04:03 PM
Just out of curiosity how much would you want for that kit?
#52 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 04:16 PM
Let me dig it out and get pics.  I will also find a receipt...
Edited by Trav1s, April 28, 2016 - 04:16 PM.
  • JC 616 said thank you
#53 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 28, 2016 - 04:22 PM
I called the machine shop and they said to clean the block and machine it will cost $65 but they won't install parts the customer brought in themselves
#54 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 04:27 PM
You can have them bore to match then install yourself.  Building a k series is not hard and the manual is available on the www.kohlerengines.com site
#55 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 28, 2016 - 07:17 PM
Yeah he said given there's enough there to only have to take out .010. Only thing I've never done myself is rings.
#56 Trav1s ONLINE
Trav1s
  • 3,299 Thanks
  • 4,356 posts
Posted April 28, 2016 - 08:23 PM
Service manual will walk you thru it.  Easy as long as you follow the order... if not you take parts out to install others.
  • propane1 said thank you
#57 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 29, 2016 - 05:58 AM
Yeah looked through it and it seems pretty simple actually. Very detailed. So if you have the block machined do you need to have work done to the head too?
#58 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,822 Thanks
  • 2,781 posts
Posted April 29, 2016 - 08:37 AM
Have u had it running yet?  Might want to get it running first to see if it needs rebuild or not.  If it don't smoke and if the compression is high enough I wouldn't rebuild it.
couple of
Edited by Delmar, April 29, 2016 - 09:02 AM.
#59 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 29, 2016 - 10:38 AM
No I haven't had it running yet. I just didn't wanna go through everything just to have to tear it back apart. It cranks but there's not any spark. Probably a good start is a battery, plug, coil, and points.
#60 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted May 01, 2016 - 04:28 AM
Can a 3 point hitch be added to the H1? Also if I found the whole H3 setup can I just swap it out and convert mine to the H3?
