John Deere 140
105 replies to this topic
#16 Leonard VanCamp ONLINE
Leonard VanCamp
  • 490 Thanks
  • 381 posts
Posted April 26, 2016 - 12:36 PM
I wont swear to it but I believe the John Deere splitter is run off a separate pump that runs off the tractor PTO.
  • michael.kitko and JC 616 have said thanks
#17 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 01:04 PM
Is that splitter a John Deere part or did someone custom make it? That's exactly what I was picturing in my head about trying to do
#18 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 01:07 PM
All this great info....I'm getting really excited about this tractor.
#19 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted April 26, 2016 - 01:55 PM
It was sold by JD. It is called a Model #4 Logsplitter. It has it's own pump, belt driven off the engine.
#20 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 02:22 PM
$800 for the weights? Sold...who wants em
#21 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 02:35 PM
Can you still find those splitters?
#22 hdg4400 OFFLINE
hdg4400
  • 283 Thanks
  • 348 posts
Posted April 26, 2016 - 05:38 PM
JC 616:
Did a little Google search, and found a topic here at GTTalk:  "Jd #4 Log Splitter". Didn't read it all but it might have some good info. Also found an already sold one on EBay, $1200.
Harlan
#23 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 07:06 PM
Wow nice find. I think I'll just make my own. Already have a 5" cylinder. Just have to figure out if there's enough hydraulic oil capacity to connect a pump to the front of the tractor or if it needs its own separate tank
#24 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted April 26, 2016 - 08:01 PM
I am pretty confident in saying the factory system will not be able to support a splitter.
#25 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 08:11 PM
Well attachments are there for this tractor that uses the hydraulic outlets?
#26 Leonard VanCamp ONLINE
Leonard VanCamp
  • 490 Thanks
  • 381 posts
Posted April 26, 2016 - 08:15 PM
The front attachments are mainly the 54 blade and 49 snow blower, you could also find brooms and other attachments.
#27 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted April 26, 2016 - 08:18 PM
In theory it could handle a splitter, it will just be really slow. Also, need double acting cylinders, so the fluid level stays kind of constant.
Blades and blowers are the common users of the front hydraulics. Sweepers and Johnny Buckets are less common, but also use the front hydraulics. I have two of these machines, and must admit they are working classics.
Mike "Squirrelly" Kitko
  • Trav1s said thank you
#28 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 08:33 PM
Ok so with this being the H1 model can I mount a rear tiller on it? Since I'm unfamiliar with the JD ways of mounting things it looks like all it has for anything to attach to the rear is a tongue probably just for pulling things with a hitch pin or something
  • michael.kitko said thank you
#29 JC 616 OFFLINE
JC 616
  • 24 Thanks
  • 140 posts
Posted April 26, 2016 - 08:34 PM
Kind of hard to see the whole rear end right now with the leaf vac attached to it
#30 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,801 Thanks
  • 2,763 posts
Posted April 26, 2016 - 08:48 PM
The John Deere #33 model tiller is the one that fits it, and you also will need the later model rear pto on the tractor to run the tiller.
Those rear weights sell on eBay for $150 to $200 per set of two. You can still buy them new from some John Deere dealers. I don't know that I would sell them, they are good to have, they help to provide traction
Edited by Delmar, April 26, 2016 - 08:49 PM.
